Where is my power steering fluid going?
Old Sep 14, 2010 | 09:49 PM
SPINPOSI's Avatar
1990 cummins non intercooled.......Last few weeks I have needed to add 2 qts of power steering fluid ... I checked for leaks but everything is dry. I did have the engine out a month ago and drained the PS pump, then when i first fired it up I forgot to fill the reservoir and heard it moaning when I backed out of the shop. Since then I have logged at least a 1,000 miles before the fluid started to disappear... any connection... I don't know.
Should I assume the fluid is going into the block? Someone told me the vac pump is burning it, but I don't see how that is mechanically possible.
-Jason
Old Sep 14, 2010 | 10:14 PM
dieseldawg604's Avatar
check your oil see if its higher that normal!!
Old Sep 15, 2010 | 06:28 AM
GIT-R-DONE's Avatar
YES, check your oil. The vaccum pump seal can go bad from what I understand
Old Sep 15, 2010 | 06:37 AM
SPINPOSI's Avatar
The oil level is between the marks but it does seem runnier than normal.
I looked at the FAQ page about Vac pump rebuilds, seem pretty straight forward to replace the seal.
Who do I get the seal from? Dodge, Cummins or a parts house?
Thanks- Jason
Old Sep 15, 2010 | 08:10 AM
GIT-R-DONE's Avatar
Check out this thread:
https://www.dieseltruckresource.com/...p-t275948.html
Old Sep 15, 2010 | 01:16 PM
SPINPOSI's Avatar
Yep same deal only no brake fluid...
Guess I'll put it apart and if anything exciting is in there I'll take some pics!
-Jason
Old Sep 15, 2010 | 01:21 PM
SPINPOSI's Avatar
Being non intercooled, is my setup different than a 1991.5 & up?
Old Sep 15, 2010 | 02:08 PM
Onemoparnut's Avatar
Yes ic and non ic are different.
Tommy93w350
Jun 26, 2007 04:42 PM
perk
Jun 11, 2003 09:10 AM
Dieseldude4x4
Jan 31, 2003 10:48 PM
BLK_RAM
Jan 18, 2003 10:14 AM
