03 6bt into a 82 crew cab
im looking at buying a 1982 Crew Cab Short box that currently has a 360 with a 4speed manual trans and i might be able to get a 03 cummins 24v 6bt out of his ram and his 46re 6 speed trans and im looking at swapping the motor and trans from the 03 into the 82. the cab and bed are being pulled off for paint and bodywork anyway. how much work is this project going to be and is there anything in specific i need to watch out for?
Have a look in the 'conversions' forum on this site, I'm sure there's a bunch of good info in there. And for some reason I think there's a site dedicated to Cummins conversions.... cumminscoversions.com? Something like that. A Google search will get results, I have no doubt!
Also the 24v 5.9 is an ISB, not a B series. http://www.cumminsdieselspecs.com/24v.html
You can check out destroked.com and painlessperformance.com parts and wiring.
Check out Johny5's crew build thread...should give you an idea of what your in for.
https://www.dieseltruckresource.com/...b-t230012.html
for the OP, destroked has the Zues Stand Alone ECM for common rails... http://www.destroked.com/zeus/index.shtml
yeah i know id have to use diff gauges. im thinking of working a way to fiberglass custom the dash and put the 03 gauge cluster in and run 03 gauges because ill be getting the 03 motor and trans and everything for free so itll be worth it to do some work to make it work. and it would definitely be unique
