where to get a new throttle turnbuckle?
Old Jan 3, 2009 | 04:32 PM
team's Avatar
where can I get a new throttle turnbuckle? one of the ends on mine is metal and the other end is plastic and the plastic end has broke.
Old Jan 3, 2009 | 05:27 PM
gear jammer 91"'s Avatar
I would try the dealership, or you might get lucky at and the local hardware store might have something that would work.
Old Jan 3, 2009 | 06:09 PM
R C Cola's Avatar
Turnbuckle
Last summer I ran into this problem. At that time my dealer said order it in for $ 57 plus freight. I did some looking and best find was WW Grainger matched up one that they use (called it a control rod ) to close heating vents by remote control. Very sturdy unit with ball ends & heavy duty compared to ours expect it to last forever. Had to drill one hole for the mount for the end towards the firewall to mount to a little extra effort great repair all brass and steel. I did the work so cost total with the rod I had to buy was about $ 8 dollars. Cost 4 hours looking for replacement part and 30 mins of install time.
Old Jan 3, 2009 | 06:42 PM
Montana2x2's Avatar
Cummins Part# 4089076 around $25 for the whole rod and ends.
Old Jan 3, 2009 | 09:57 PM
AUGIE DOG's Avatar
What Montana said!!! Call or go to a cummins dealer in your area, give them part# and get the whole assembly. It's a whole lot easier and fixed the proper way. I believe the price may have gone up when i purchased mine from Mid Atlantic Cummins in Greensboro,NC. I believe it was $35 and some change. Don't piece part repair it FIX IT RIGHT! The part is not that expensive
Old Jan 4, 2009 | 01:06 AM
bigragu's Avatar
Yes, and the Cummins ends are metal, not plastic.
Old Jan 4, 2009 | 04:34 AM
Jim Lane's Avatar
Post
That is what I did...
I made my own.
I got the Heim Joints from my local Specialty Fastener Shop.
The one on the right hand side where you see the ring around the end by the nut has a left hand thread so it fits the factory threaded rod.
I had to remove the old ball stud with a die grinder. With this new link there is absolutely ZERO unwanted movement.
All of the parts were about $25.00
Jim
Old Jan 4, 2009 | 09:05 AM
apwatson50's Avatar
I made my own.
Jim
Do you happen to know what the thread/pitch is of the rod?
Thanks, Aaron
Old Jan 4, 2009 | 09:48 PM
Jim Lane's Avatar
Thanks, Aaron
Aaron,
I am almost certain it is an M-6 6mm x1.0
The Heim Joint with the band around the end has a left hand thread.
The ball takes a 6mm bolt; I used a bolt and a Nylock nut.
Jim
ramtd02
Aug 27, 2004 05:22 PM
j
Oct 12, 2003 11:25 PM
Mostwanted
Aug 14, 2003 07:43 PM
TPilaske
16
Jan 11, 2003 08:34 PM
frank
Nov 1, 2002 04:34 PM
