Wheels
Old Nov 9, 2008 | 09:58 PM
Ezra's Avatar
Wheels
Will these specs work on are trucks.....16x8, 8 on6.5 Bolt Pattern....Backspace 4.50 in.....Max Load = 3200lbs Finish = Matte Black.....Hubcentric = No Offset = 0 mm ?? Ezra
Old Nov 10, 2008 | 12:02 AM
PapeCAT's Avatar
the hubcentric actually sounds like they're for chebbies.. Why do you need aftermarket wheels?
Old Nov 10, 2008 | 08:36 PM
Ezra's Avatar
Cause i want'um..
Old Nov 10, 2008 | 10:55 PM
NotEnufGarage's Avatar
Those should work. I have 16x7's with 3.75" backspacing, so those will tuck in just about 1/4" more than mine. I have 33x10's on mine, no lift, no rubs.
Old Nov 12, 2008 | 11:32 PM
tcs 91's Avatar
i use 18x10's w 5" backspace on the rear. 3.25x60x18 on the back for the street.[my overdrive] truck is lowered 2". lot's of room. tc
Old Nov 12, 2008 | 11:39 PM
tcs 91's Avatar
while we're on the subject, does anyone know where you can find alum whls in 15" with about a 3.5" backspace for a set of rear slicks. seems like most of the diameters i'm interested in [3.07 rear]are in 15". all i can find are steel whls. probably want 10" wide. tc.
Old Nov 13, 2008 | 01:53 AM
PapeCAT's Avatar
try giving stockton wheel a call. They specialize in wheels. They prolly have some 15x10 8 lug on the shelves
Old Nov 13, 2008 | 09:07 PM
wheelo90's Avatar
To go with a 15 inch wheel, I'm almost certain you will have to grind the calipers down to prevent the wheel from rubbing the calipers. I know I had to on mine, it sucked, but was worth it!
Wheelo
Old Nov 14, 2008 | 08:32 AM
93Fury's Avatar
Wheelo
He said a pair for REAR slicks.
Old Nov 14, 2008 | 08:52 AM
vwjunkie53's Avatar
I'm looking for a set of wheels for my D-250, anyone know the stock width/backspacing of the 16" steel wheels? I would like to get something close to the same so they don't stick way out.
Thanks,
Jason
Old Nov 14, 2008 | 10:47 PM
wheelo90's Avatar
Sorry about that, long day at the power company ! Yes 15 inch will work on the rears.
bucknasty
Jan 10, 2008 06:52 PM
tontof18
Sep 28, 2006 07:59 PM
Dave88LX
Jul 13, 2005 08:34 AM
Gary C
27
Mar 11, 2004 07:42 PM
