whats the deal with these injectors?
Old Aug 15, 2009 | 04:21 PM
Anyone know whats up with these? I'm finding them all over the place now on un-popular diesel performance sites.
Bosch "230" 92-93 injectors http://www.truckdieselparts.com/indu...1989-1993.html
My dad had some Bosch 230's in his ole' 95 p-thumper and they were pretty smokey but really woke that thing up.
just curious...
Brandon
Old Aug 15, 2009 | 04:47 PM
dzl_damon's Avatar
I know there are some boats around here with rotary pump B series that have 230hp stamped on their timing cover. Perhaps these injectors along with their stock 3200rpm springs make them 230hp vs 160hp?
Old Aug 15, 2009 | 08:42 PM
Richie O's Avatar
366 Spring Chicken
Are they lucas cav pumps or bosch ve's?
Old Aug 15, 2009 | 08:52 PM
I wonder if thats what the deal is with Bosch 190's and Bosch 180's (you never see).
There just horsepower rating, So a 180Hp bus would prob have "Bosch 180's"
Old Aug 15, 2009 | 09:18 PM
Riflemanusmc's Avatar
Registered user
Do a search Brandon. Bet the piston bowl/piston was differant.. let us know what U come up with....
Old Aug 15, 2009 | 10:53 PM
I/c and Non i/c trucks have different piston bowls, Hence the reason Non i/c trucks like POD injectors...Thats really what the piston bowl was designed for. The stock injectors are 4x.012 and the POD's are 4x.014...
Then emissions people rolled along and said :nono: to emitting black smoke, Added cleaner running injectors (6x.009), 21cm lagmaster housing, Intercooler, "Smaller" pump, and reshaped the piston bowls.
ughhh... i hate being sick.. i can take something that would take 2 sentences to get the point across and make it so long i get my self confused.
Old Aug 15, 2009 | 10:59 PM
Richie O's Avatar
366 Spring Chicken
Pig Flu!
Old Aug 16, 2009 | 01:17 AM
SeanB23's Avatar
I understand that the 92s had lousy injectors and the 21sq cm lagmaster, but what's this about a "smaller" pump ?
Old Aug 16, 2009 | 07:09 AM
Might want to do a little more research on your piston theories.
Old Aug 16, 2009 | 10:42 AM
justin mcfall's Avatar
Captain Google to the rescue!!!
Old Aug 16, 2009 | 11:11 AM
Do I Have it the other way around ???
Old Aug 16, 2009 | 04:07 PM
92roughstock's Avatar
NonIC and IC trucks had different piston bowls. Seems to me the IC were a little shallower and wider, while the IC almost has a lip around the edge of the piston bowl, and is noticeably deeper.
The "smaller" pump has to do with fuel rate- 78mm/stroke with the nonIC vs 74 with the IC.
Old Aug 16, 2009 | 05:29 PM
dzl_damon's Avatar
didn't see your post Richie. I never really knew that they had a different pump, but my friend that works at Billings Diesel told me he had a few rotaries out back left over from some repowers. He was looking at my utility truck with the screwed up pump (that I'm changing now actually) and said that my pump was much smaller looking than the 230hp B series they had at the shop, and he doubted they would be swap right over. I'm sure they didn't have an AFC housing on them also as most industrial engines don't.
So, I'm betting this different rotary pump was the Lucas CAV. Never heard of them before you mentioned them though.
Old Aug 16, 2009 | 07:38 PM
Registered user
Yea, I'm pretty sure you do... Sit back, take a breath....STOP USING GOOGLE!!!!!!!!!!!!!!!! You don't have to be a post king man..Stop it !.Did I not send you a PM???
Old Aug 16, 2009 | 08:20 PM
gadget.35-06's Avatar
Nippondenso also made pumps for some OEM apps of the Cummins.
