Whats the biggest turbo for pods?
Old Jul 31, 2007 | 05:49 PM
rbrettctd's Avatar
Like it says...Ive got Pods right now. Would upgrading my HX35 to a stage 3 (35/40 hyrbid) be substantial and worth the money, or should I wait until I upgrade injectors next summer and go with an s300 or the like? If I do the stage 3 it will be when I go intercooled.
Old Aug 1, 2007 | 12:11 AM
MikeThomas's Avatar
You could try one of these:
Old Aug 1, 2007 | 01:16 AM
gman07's Avatar
With POD's already, don't waste your time and money with a hybrid.
Old Aug 1, 2007 | 06:12 AM
JD730's Avatar
Couldn't have been said better. My HTB2 62/12 will cool it pretty well, but will still get hot on the WOT blasts, still seeing 1400* on a hard romp.
Old Aug 1, 2007 | 08:47 AM
G1625S's Avatar
Yup, I would have said HTB2. The real problem with POD's is they just aren't that efficient. An EDM that flows the same fuel will run a ton cooler with the same turbo.
Old Aug 1, 2007 | 12:28 PM
rbrettctd's Avatar
So yall are saying stick with my 35 until im ready to upgrade injectors? Ill be going to edms, probably next summer...
Old Aug 1, 2007 | 03:15 PM
No, you can put an HTB2 (or whatever you think you want) on now, the POD's will flow enough fuel to spool it nicely.
Old Aug 1, 2007 | 03:55 PM
rbrettctd's Avatar
Okay, but the hybrid 35/40 wont be worth it? Im just saying cause its $250 and the cheapest HTB2 Ive found is some $900, I guess an S300g falls under the HTB2?
Old Aug 1, 2007 | 04:01 PM
Yeah, a hybrid is marginal with POD's and a cranked up pump. Go even bigger on the injectors and it's just hopeless (I oughta know ) No sense spending $250 now and $1000 later, just spend the $1000 when you can and be done with it.
Old Aug 1, 2007 | 04:30 PM
rbrettctd's Avatar
Has anyone ever said they were done spending money on their truck and it work??? Ive said it many times....but it aint working . Its fun though.
Old Aug 1, 2007 | 07:20 PM
dpuckett's Avatar
One thing to keep in mind is that when the time comes, you can usually sell the HX35 hybrid for what you have in it in parts, thus costing you nothing. If you have the cash, get the hybrid (or kit to make it a hybrid), and run it til you get your EDMs. You may or may not need the bigger huffer, though more air never hurts. Also, keep in mind you will drop your EGT considerably with an intercooler.
Daniel
Old Aug 1, 2007 | 09:28 PM
rbrettctd's Avatar
Daniel
Im thinking Ill save my money and go with an intercooler only. I need to be reasonable and realize I dont really need so much power. However, I REALLY want it. I really dont have much smoke right now except when Im spooling in 3rd and 4th, nothing if I kept it spinning while shifting. Im gonna concentrate with getting her intercooled first and go from there. If I feel I need the extra power before next summer Ill do the hybrid. My bro will be doing a 4 or 6bt transplant in his 93gmc sometime so this hx in whatever form will be going on there most likely.
kujo
16
Apr 19, 2012 08:13 AM
92smokin blacky
Dec 28, 2011 07:26 PM
texasredrider
32
May 13, 2007 09:13 AM
JKM
May 7, 2007 10:26 PM
twistingawrench
Sep 21, 2006 11:30 AM
