What type oil and how muchin fresh getrag?
Should get my rebulit Getrag tranny back tommorow and try to put it back in this weekend. What oil should I run to start with? 5w-30 and then drain after a few thousand miles? Then synthetic?. I know they need to be overfilled but I read the other post on here where someone said they put in 7 quarts? Is that overkill? Can you actually fit that much in the tranny? Thanks, Matt
Most folks add about a litre and a half or two of your little quarts above what the spec's call for. I just remove a bolt from the top of one of the pto plates and fill till it starts to run all over. I "think" it is about right. The Getrag is a good gearbox and I will trade it's low rpm rattle and need to be overfilled for the bad fifth gear of the NV's any day. The getrag is a much under-rated tranny IMHO opinion any way. I pull a fifth wheel long distances every year and have yet to have the Getrag give me grief on the road. Keep the rev's up and overfill it and it will treat you right.
http://www.fastcoolers.com/
I would do regular 5w30 then change to synthetic after a while, just to make sure you don't have any leaks, etc...
kram
Aug 29, 2007 11:01 AM
1sttruck
Mar 14, 2004 02:26 PM
BILL DODGE2003
Mar 7, 2004 09:51 PM
