What Turbo?
Old May 18, 2009 | 07:12 PM
SMKHZRD's Avatar
What Turbo?
What turbo will go good with some 6x.016 injectors..i was thinking about going with the s300g because i do some towing...What u guys think?Also still want to smoke ricers..
Old May 18, 2009 | 08:25 PM
PDR super hx40
http://www.pdrdiesel.com/products/PD...s-1086-26.html
Your gonna wanna gate it at like 35-40 psi or you'll hurt the headgasket.
an S300G would be too small for 6x16's and pump tweaks
Old May 18, 2009 | 08:32 PM
peobryant's Avatar
With stock pump settings, you could run either an HX40 or S300G, but with pump tuning, it will get hot, especially while towing.
I've always been told that even the baseline S300G will flow more air than an HX40, but I'm not sure if that applies to the "Super."
For under 400rwhp, the Super HX40 is a great turbo, for towing and daily driving, but over that is S300 territory.
Old May 18, 2009 | 08:41 PM
SMKHZRD's Avatar
I thought that the hx-40 was smaller than a s300 and flowed more air..so wouldnt the s300 be lower egts than the hx-40 because it flows more air.
Old May 19, 2009 | 01:50 PM
peobryant's Avatar
Yep, the S300G will flow more air than a regular HX40. I'm not sure how it compares to a Super HX40 though.
How do you plan on keeping your pump tuned? Are you panning on keeping the fuel screw turned in?
If you are, I would go straight to a 62/71/14 S300.
Old May 19, 2009 | 04:01 PM
And its modified by PDR...
gearjammer has one.
Old May 20, 2009 | 12:04 AM
SMKHZRD's Avatar
umm depending on how hot it gets..is whether i turn down fuel screw..will that 62/71/14 be ok for some towing?
Old May 20, 2009 | 12:08 AM
peobryant's Avatar
It's a little laggy, but when it lights, it spools real quick.
Old May 20, 2009 | 12:13 AM
SMKHZRD's Avatar
Will my egts drop alot...right now i can peg 1500 degrees with the h1c upgrade and ddp stage 3....but what u think i would be doing with the 6x.016 and 62/71/14?
Old May 20, 2009 | 12:35 AM
peobryant's Avatar
It really depends on the fuel screw, but I'm sure you could keep it under 1200*.
Old May 20, 2009 | 12:43 AM
SMKHZRD's Avatar
Sweet what kind of power u think i could make with that combo? You know i was just planning on doing some small stuff but now look at me...
Old May 20, 2009 | 01:21 AM
SOOT4BRAINS's Avatar
Pod Boy (on hiatus)
Yea! now look at you! Breaking trannies, breaking flex plates, tearing shut off solenoids, using all my spare parts, constantly calling me cus ur truck is doing something wierd....... Take a hint.... Your truck doesnt like going fast...... And you want to make it faster......
Old May 20, 2009 | 02:00 AM
Crazy Matt's Avatar
Nothing cubic dollars and upgrades doesnt cure
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
