what to look out for???
Old Mar 23, 2005 | 02:02 AM
nauitque21's Avatar
i'm new to CDTs and i was just wondering if any of you could help me out by listing things that i should look out for in the 1st gen CDTs.
i've heard that the Getrag transmissions are crap and i should spend the extra time and money and effort to get a 5 speed.
any thing else that i should look out for and maybe some warning signs that a regular gasser guy wouldn't know to look for?
thanks
-Bryan
Old Mar 23, 2005 | 09:13 AM
The Getrag is the 5 speed. I wouldn't say they are crap, but they don't tolerate abuse and neglect well. Gear noise at low RPM is normal, but if it's noisy all the time and/or jumps out of gear it's toast.
https://www.dieseltruckresource.com/...threadid=60608 Covers differences between gas and diesel.
Watch for rust, some is easily repaired (floors, rocker panels), some isn't. If you see any rust above the windshield, even bubbles, run away! They rust from the inside out up there and it's much worse than it appears.
Old Mar 23, 2005 | 12:11 PM
FrdRdnk's Avatar
Dave correct me if I'm wrong but I think in late 91 they went to the nv4500 which is supposed to be stronger. I'm just goin on what I've been told.
Old Mar 23, 2005 | 12:26 PM
nauitque21's Avatar
did they ever put in NV5600s in the 3/4 or 1 ton 1st gen trucks?
i'll be sure an look out for rust!!! thanks for the info!
any common diesel engine problems or are they pretty solid?
Old Mar 23, 2005 | 01:06 PM
jiMMyCTD's Avatar
nv 4500 started in 94
Old Mar 23, 2005 | 02:15 PM
What he said. '89-'93 have the Getrag G360.
Old Mar 24, 2005 | 04:03 PM
SmokinFive9 4x4's Avatar
Frame cracks at the steering box right on top where the small notch is behind the radiator support, not a huge deal, but it'll need welded. I've noticed it alot on these trucks and heard other's stories on here as well about it.
Old Mar 24, 2005 | 05:09 PM
92DIESEL's Avatar
KDP Its a dowel pin that has a nasty habit of dropping at the worst time . tab it or set screw it!
Good luck and if you keep up on pm you wont get stuck.
Oh and dont run out of fuel it is a PITA
Old Mar 24, 2005 | 05:21 PM
nauitque21's Avatar
SmokinFive9 4x4
thanks for the tip! i really like your truck!!! that thing is sick! what happened to the piston? looks like a melt down... i know old chevys used to have a similar problem.
92DIESEL
hmm... what's a KDP? sounds like an easy fix.
this is just what kind of stuff i was looking for. it's nice to come to a forum that knows how to answer questions and doesn't get all ****** off when you ask a question. that's what forums are for right? i'll quit my rant now
Old Mar 24, 2005 | 09:10 PM
https://www.dieseltruckresource.com/...threadid=36809
The best KDP thread on this board. Read it and the ones it links you to. KDP damage is not as common on 1st gen trucks as on 2nd gen trucks, but it still happens.
Old Mar 25, 2005 | 07:34 AM
92DIESEL's Avatar
What he said ^
bsj04
Jun 30, 2007 03:31 AM
Dodge@KY1997
21
Feb 4, 2007 08:00 PM
97CTD
Mar 17, 2003 09:12 AM
