What to look for on HX35s
Old Aug 23, 2007 | 08:43 AM
andyr354's Avatar
Looking at classifieds and such for HX35 turbos and don't know what to look for.
What years will bolt on the easiest?
What is needed to make them fit?
It it worth it to get one, or just put a 12cm on what I have and call it good?
Pulling a trailer with the slow spool of the 18.5 makes up shifting a PITA at times.
Andy
Old Aug 23, 2007 | 12:10 PM
rbrettctd's Avatar
12 valve ones work the best (95-98). They are pretty much a bolt in for intercooled models, though with the wastegate housing the downpipe needs to move back about an inch. There is a very significant and noticeable difference in hx35 and h1c. If you pull heavy loads often youll probably wanna find a 14cm wastegate, but Im no expert on the 12 so it may not heat up too bad.
Old Aug 23, 2007 | 01:29 PM
The 12 cm works awesome with stock injectors.
Old Aug 23, 2007 | 03:02 PM
Ace's Avatar
Ace
I can heartily confirm that!
Old Aug 23, 2007 | 04:02 PM
Falcon1's Avatar
Me too, but now I got me a 16 on my hx-35.
Old Aug 23, 2007 | 04:23 PM
andyr354's Avatar
well, now just to find me one!
Only one I found so far is from an 02 model year
Old Aug 23, 2007 | 04:50 PM
rbrettctd's Avatar
Just dont pay too much for one-you can get a piers hx35/40 hybrid with a 16cm housing for around 650. I picked up my hx35/14cm wg housing with a bad wastegate actuator on it for $200. Craigslist is a great place to start. Ebay is alright, but some people have had problems with the ones they got.
Old Aug 23, 2007 | 05:02 PM
andyr354's Avatar
I almost think I would rather have the 12cm for the price vs a 14. I am not pushing huge power or after market injectors. I am 1 turn past the lock collar on the pump and have enough power for my needs now.
I just hate that dark cloud of black smoke and no power under 1400 rpm because of the lazy turbo. I have to run up to 2500rpm or more to make some of the shifts with a load when not on level ground.
Old Aug 23, 2007 | 08:15 PM
ez_lle71's Avatar
I found my hx at a local junkyard. Had it layin' on the shelf. Its worth a try. Hess and sons salvage, Junction City Kansas. They are one of the few yards around here that will even think about carrying anything dodge cummins! Most yards say "don't have em, don't want em!"
ez
Old Aug 24, 2007 | 11:31 AM
andyr354's Avatar
I called them, you got the good deal!
What years exactly did they use the HX35? Was 94 the only year for the WH1C and they went to it in 95, or was it 96?
Old Aug 24, 2007 | 04:55 PM
ez_lle71's Avatar
Sorry! My dad, 95' has a WH1C! Normally 95' thru 02' standard tranny trucks and auto trucks to 2000 i think. the later autos use a hy-35.
good luck
ez
Old Aug 24, 2007 | 05:10 PM
A WH1C is just as good as an HX-35. Get whichever you can.
bsj04
Jun 30, 2007 03:31 AM
Dodge@KY1997
21
Feb 4, 2007 08:00 PM
97CTD
Mar 17, 2003 09:12 AM
DarrellB
Mar 13, 2003 03:22 AM
