What kinda vacuum should I be seeing?
Old Sep 2, 2011 | 10:55 PM
BearKiller's Avatar
Originally Posted by 9MM
Okay if I ran one pump that's making about 16-17in of vacuum and put a vacuum canister on it would that work over the two pumps my brake peddle still sinks with only one pump hooked up.
I think you have other issues than a bad vacuum-pump.
The vacuum pod may very well be bad, but I don't think that is your only issue.
Poor vacuum will usually do the reverse and make the pedal nigh impossible to push to the floor, even push the pedal back upwards at you.
It reads like you have a hydraulic issue going on.
Old Sep 2, 2011 | 11:11 PM
9MM's Avatar
9MM
It's not I have bled the brakes for 3 hours a couple days ago new master cylinder the brakes will lock the tires the peddle just sinks to the floor slowly but if I keep the rpm's about 1000 n push the brake peddle it won't sink till I let off the throttle n the vacuum comes down a few pounds.
Old Sep 3, 2011 | 12:46 PM
BearKiller's Avatar
That reads more like a bypassing master-cylinder or a leak in the hydraulics somewhere.
Vacuum or no, the pedal should remain firm.
Vacuum is measured in inches-HG, no pounds involved.
Old Sep 3, 2011 | 01:04 PM
9MM's Avatar
9MM
I replaced my master cylinder a few days ago with a brand new one it works fine I don't have any leaks either I was over the brake system a dozen times.
I fixed my problem temporarily till I know what is going on with workers compensation. I made a vacuum canister n I have firm brakes now.
jimbo486
May 8, 2016 06:07 PM
t_oad01
Oct 7, 2011 07:38 PM
cmed250f
13
Sep 3, 2010 09:18 PM
01smoker
Oct 31, 2007 10:14 AM
Joe T
38
Apr 30, 2007 01:01 PM
