What Boost should I be seeing?
I have a 93 with a Denny T pin, 3200RPM spring, and 4" exhaust, K&N intake, with everything else stock. I see about 25psi of boost. Someone was telling me that they thought I should be seeing highter boost. What do you think?
Thanks.
Thanks.
Have you tinkered with pump besides the pin? I would say 25 is good with the stock turbo. I have similar setup but 2nd gen intercooler and highest I see is 25 to maybe 27. You won't see too much more with out a compressor wheel upgrade or smaller housing.
Sounds about right if those are the only mods you've done to a bone stock truck. Mine would barely make 20psi on a good day, if I was lucky.
SpeedyWS6
Sep 4, 2011 12:30 PM
Aosipower
31
May 2, 2007 02:48 PM
TON4FUN
Jan 15, 2003 11:17 PM
