what kind of power
Old May 4, 2008 | 08:28 PM
  #31
angelfire7's Avatar
Originally Posted by Alwaysworking
i can get a 12.25 stock replacement
what makes the 13 better than the 12.25?
The 13 inch Con OFE from Southbend has been modified to accept the 1.25" input shaft which means that it is 2-3 larger an stronger than what the 12.25 can provide. Rated up to 450 HP and 1000 ft. lbs. of torque. I have one and often tow a 10k plus trailer here in the N.Ga mountains with no problems what so ever. If you go with a 12.25 with beefed-up springs, the springs will hold but the spring seats will disintegrate and dump metal tabs in between your flywheel and friction plate causing slippage under load. This very thing happened to me so I bit the bullet and sprung for the Con OFE from Southbend and couldn't be happier. Take a look at my signature for my power ratings.
Hope this helps.
Peace,
Joseph
"In God We Trust"
Old Feb 3, 2009 | 02:26 AM
  #32
Alwaysworking's Avatar
alwaysonDTR
time for a new one again, dont hold anymore.
Old Feb 3, 2009 | 02:34 AM
  #33
pulltilbroke's Avatar
Best Paint (Getrag category)
UH-OH
Time for a Iron Giant?
Or you can try this place
http://www.kennyspullingparts.com/1812316.html
This truck has one of there triple disc pullin clutches
http://www.youtube.com/watch?v=hf9zd...eature=channel
http://www.youtube.com/watch?v=0V3fw...eature=channel
Old Feb 4, 2009 | 01:30 AM
  #34
alwaysonDTR
well the clutch i have is sapossed to be warranty'd so i'm going to check into that first, and also look into the heavy duty model they have
Old Feb 11, 2009 | 01:30 PM
  #35
alwaysonDTR
called up the place i got my clutch from and they said they might warranty it they have to see it first with the flywheel and they dont really have any options for me to upgrade to since i have 3.54 gears.
Old Feb 11, 2009 | 01:54 PM
  #36
pwrtripls1's Avatar
call Peter at SB, the 3250 DD may work for you.
Old Feb 11, 2009 | 07:35 PM
  #37
alwaysonDTR
i wish i could do that.
how well do Double disk shift at high rpm?
Old Feb 13, 2009 | 01:52 AM
  #38
alwaysonDTR
old ones out.
Old Feb 13, 2009 | 08:56 AM
  #39
apwatson50's Avatar
I don't know how well they shift at high rpm, but everyone says they shift slow. I would imagine they would shift better at a higher rpm, but ???
Well I was going to ask if you have seen the dtr special for the southbend, but just checked here and its not on special anymore
http://store.dieseltruckresource.com/sobedudi32du.html
It was $1000.
What are you going to go with?
Aaron
Old Feb 13, 2009 | 10:47 AM
  #40
bgilbert's Avatar
Originally Posted by bgilbert
Kids just don't wanna listen.
What he said. Just like a junk parts store like Autozone. Sure they've got a warranty, but when your junk part, in this case, your clutch fails, it gets replaced with an identical junk part. No way out of it except, spend your money again on a superior part. Stock 13" Sachs clutch, call South Bend.
Old Feb 13, 2009 | 04:52 PM
  #41
Yeah, I've had very good luck with the stock Sach's, I've only had to reline it once
Old Feb 13, 2009 | 07:19 PM
  #42
pwrtripls1's Avatar
From talking to Peter the one he's making me will shift just fine at high RPM. Thats what I got it for, extreme holding power and quick shifting since I need all the help I can get if this tank is ever going to run 12's. lol
SB recomended the 6 button 3250 plate load instead of the 12 button 3600 plate load for quick shifting and drag racing. These are prety much the same as the ones a few 800hp common rails run. My little VE 12v will never hurt that thing.
Old Feb 14, 2009 | 11:36 PM
  #43
alwaysonDTR
i got a full ceramic(has 8 pucks on it) 4,000lbs plate load luk clutch.
the place i got the other one warranty'd it so i just paid the difference and went ceramic, they said i shouldn't be able to slip it.....will see.
they did not want to sell me this clutch because of my high gears and what i'm doing with the truck said it would be grabby. they also said the hotter it gets the better it grabs
Old Feb 15, 2009 | 12:52 AM
  #44
Richie O's Avatar
366 Spring Chicken
I bet it will be grabby. I drove a topkick with a ceramic clutch and it squealed like crazy when you tried to ride the clutch if you were in a tight spot.
Old Feb 15, 2009 | 01:48 AM
  #45
alwaysonDTR
as long as it holds
