what is kdp?
Old May 15, 2005 | 05:21 PM
frijoli's Avatar
what is kdp?
I tried doing a search, but the search engine keeps telling me that the word kdp is to small to search.
Newbie to Cummins trucks. Please help.
Regards,
Clay
Old May 15, 2005 | 05:29 PM
jiMMyCTD's Avatar
killer dowel pin. (its a pin that resides in the timing case*ithink* and it is prone to wiggling out and cracking the housing because it gets jammed in teh gear. should find a ton of info in the tech section of the website. thanks for the reminder i still need to get mine taken care of one day!
he he, jiMMy
Old May 15, 2005 | 05:39 PM
59FORD's Avatar
Do your search with kdp* and it will work.
Old May 15, 2005 | 06:21 PM
frijoli's Avatar
Thanks all. Where did the name come from?
Clay
Old May 15, 2005 | 09:20 PM
Begle1's Avatar
That's a good question... I haven't been around for that long...
Old May 17, 2005 | 01:26 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
it starts with the new 1994 timing covers. it is called the killer dowel pin becuase when it wiggles out it is notorious for killing the timing cover and i have heard of it damaging timing gearsets and in a few cases i think it has killed the motor. I know mine wiggled out enought to let the gasket behind the timing cover gasket tear. the $1600+ is going to be a "killer" my wallet
Doah: I guess it does involve Gen 1s also
Old May 17, 2005 | 03:17 PM
92DIESEL's Avatar
the KDP also applies to the 1st gens, just not as much... ask wannadiesel for more info
Old May 17, 2005 | 04:58 PM
BC847's Avatar
1st Generation Admin
Here's a example in a '93 CTD:
The typical fix is to modify a washer so as to block the pin from coming out and falling into the gears and/or case with catastrophic results.
I bent up some coat-hanger wire:
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
SjLingenfelter
Jul 19, 2003 05:14 PM
WalkingHorse77
Mar 19, 2003 12:27 PM
gofastman
Mar 19, 2003 10:29 AM
