what gauges?
The mechanical lift pumps on the 12 valve engines don't generally have problems, so I don't really see a need for fuel pressure there unless you really want one. The 24 valve engine is totally different in that the stock lift pump is garbage the way Dodge implemented it, so a fuel pressure gauge on a 24 valve truck is mandatory. I wouldn't worry about it on a 12 valve truck though.
Engine oil temp would be interesting, but also not strictly necessary.
HTH
The ones I'm getting are Pyro - 1600, Boost - 60 PSI, Fuel Pressure - 30 PSI.
The fuel pressure is good for basically what RuralCruiser said. Plus, you can also see it drop slightly when it comes time to change your filter. Monitoring the pressure is a good way to tell if the LP is bad if you experience a sudden decrease in power, also.
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
estesbubba
Jul 18, 2006 04:35 PM
AggiePhil
Jan 30, 2005 01:15 PM
