wh1c vs hx35
Old Dec 21, 2011 | 03:06 PM
rollin_coal89's Avatar
Question wh1c vs hx35
What's the difference between them. Any pros or cons?
Old Dec 21, 2011 | 03:34 PM
G1625S's Avatar
The only difference between the two chargers is how the compressor housing is attached to the center section. WH1C uses a v-band clamp and the HX35 uses a large snap ring. Beyond that, they are identical from a performance standpoint.
Old Dec 21, 2011 | 11:01 PM
Wat kind of performance does it give over the stock turbo? Wat do our stock turbos boost?
Old Dec 22, 2011 | 05:12 AM
Douglas2's Avatar
Not exactly the same...the 24V variants have a 58 lb/minute flow rating v. 52 lb/min for the 12V. The 24V have a 7-blade compressor wheel that has a 77 mm major diameter v. 83 mm for the 8-blade. In practice it does seem they're pretty close.
cheers,
Douglas
CaptainChrysler
Oct 24, 2008 01:29 PM
sammy340
Oct 7, 2004 05:54 PM
Crimedog
Jun 23, 2004 09:06 PM
wannadiesel
Apr 27, 2004 06:32 PM
boostnCummins
Jul 26, 2003 03:26 PM
