Wh1c
Wh1c
I have the WH1C turbo on my 1st gen. and i think i am overboosting it. i push between 33-35psi and fixing to be alot more. Will the 60mm compressor upgrade be a good investment or do i need to get a different turbo? If the compressor housing upgrade is a good investment where can i get one?
thanks in advance
thanks in advance
The one i found was here http://htturbo.com/cu.htm and they want $350 is that a fair price or should i evest in a bigger turbo?
Governor spring is in the mail along with a Denny T fuel pin, pump is maxed out, and i have a 12cm wastgated housing, so im not to far away. What is "Timing set at 2mm of lift"?
thanks
thanks
Its the what the plunger lift in the injection pump measured at Top Dead Center, I think the typical 1/8 bump gets you close to that. You would need a dial indicator and the location of TDC to do it.
