welding my frame question
Old Oct 22, 2010 | 05:27 PM
bradshaw106's Avatar
after discovering some excessive rust on my frame i decided to plate the sides of it. i only have a 110v mig so i cant go to thick. the worst part is back by the shackle hanger it is solid just thin. I was planning on using 3/16" plate
on the sides where the frame goes wider, after the wheel well i was going to use 1/8" because it isnt bad at all. Across the bottom from bumper to the cab i am going to plate it with 3/16" the worst part is where the fuel tank mounted. its pretty bad...
what does everybody thick about the size plating I want to use.
Old Oct 22, 2010 | 05:46 PM
Onemoparnut's Avatar
That sounds like a good plan to me.
Old Oct 22, 2010 | 05:49 PM
Blueboy's Avatar
I don't think you will have any problem with 3/16 as
long as the metal is good around that area.
I took 22" out of my frame, put it back together
with 3/8 plate.
Another member, Morse did the same as me took
22" out, used 3/16 to put together.
Old Oct 22, 2010 | 05:58 PM
any suggestions on welding it on?? was thinking about drilling a hole with a hole saw every so often that way i could weld the center of the plate to the frame instead of just the outside edges... but i am going to be bolting on frame brackets so that would probably hold it...
just thinking out loud...
Old Oct 22, 2010 | 06:03 PM
Blueboy's Avatar
I used a step drill, on side plates, filled it in with weld.
Old Oct 22, 2010 | 06:04 PM
how big of a hole? 1/2"???
Old Oct 22, 2010 | 06:08 PM
Blueboy's Avatar
The bottom hole was 1/2 bigger at top.
I used a stick weld.
Old Oct 22, 2010 | 08:55 PM
Richie O's Avatar
366 Spring Chicken
I just welded the top and bottom. There are so many bolts for all the hangers, mounts, cross members, ect that it will be fine.
victory
22
Sep 15, 2006 11:02 AM
csramsey640
Jul 3, 2006 07:10 PM
clifford
Oct 6, 2005 08:19 PM
HorseHauler
Aug 20, 2005 09:07 PM
vaquero
Jul 16, 2003 08:55 PM
