which weight gear oil
Old Apr 29, 2007 | 07:36 AM
hoghead's Avatar
I tow on a pretty regular basis usually about 10,000 lbs. I changed my gear oil to royal purple 75-90 about 4 months ago,but that seems kind of thin from what I have read here.What I need to know is what weight gear oil I should use. Price is not a problem so any help would be appreciated.
Old Apr 29, 2007 | 08:07 AM
You ought to move up to an 85W-140. Stick with a synthetic, they hold up a lot better to the heat towing heavy will generate. Royal Purple is good stuff, no reason you shouldn't buy their oil in the heavier weight.
Old Apr 29, 2007 | 09:45 AM
bigragu's Avatar
Only jumping in cause I, too, have a question on gear oils, for the NP205. 85/140 in the Lucas is what I am leaning towards, but FSM recommends 80/140. The Lucas is much thicker in coonsistency, as you all know. Which of the 2 do you prefer? Is there a difference? Keep in mind my CA temps. Currently I have ATF #4 in there.
Old Apr 29, 2007 | 12:01 PM
If you're not working it hard in 4wd you really don't need such a thick lube in there. A good 80W-90 would be better because it will flow better when the transfer case is cool.
Same reasoning goes for rears. A truck like mine that just loafs around town empty has no need for 85W-140, the thick lube will actually not protect as well because it never gets warmed up and can't flow as well. An 80W-90 is a better choice in that situation due to better cold flow.
Old Apr 29, 2007 | 01:27 PM
dieselJon's Avatar
what about the tranny?? I am going to change my fluids soon. Just wondering
Jon
Old Apr 29, 2007 | 05:18 PM
5W-30 synthetic or one of the light trans lubes like Redline MTL or Royal Purple Synchromax. A synthetic ATF will work, too.
Old Apr 30, 2007 | 05:31 AM
bigragu's Avatar
Thanks again, Guru.
John Marshe
Aug 14, 2020 09:00 PM
West Coast
Nov 22, 2011 01:16 PM
Purplezr2
Jul 25, 2011 04:31 PM
Aug 28, 2003 12:56 PM
CTD99
Jun 12, 2003 08:05 AM
