Water Pump Replace Question
Old Dec 29, 2005 | 10:14 PM
BearKiller's Avatar
Do I just grease the gasket with vaseline and screw in the new pump, or what??
89 Cummins 1st Gen.
Old Dec 30, 2005 | 10:40 AM
apache's Avatar
Huh? vaseline and unscrew?? you mean remove the 2 bolts and pull?
Old Dec 30, 2005 | 03:37 PM
It's pretty simple. Make sure there isn't any crud built up on the surface that the o-ring seals against, then put 'er back together. Takes longer to drain and refill the coolant than change the pump.
Old Dec 30, 2005 | 03:55 PM
timcasbolt's Avatar
Yes, a little o-ring lubricant will make the seal last longer. Vaseline is an acceptable substitute if you don't have any o-ring lubricant.
pwrtripls1
Apr 5, 2010 08:27 PM
schu777
Sep 10, 2009 08:50 AM
bobbywebb
Mar 20, 2007 07:47 AM
R Walter
Jan 24, 2007 08:13 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
