water and meth
Old Mar 23, 2009 | 11:32 PM
bigbaddiesel416's Avatar
From: anderson commiefornia oh ya you can keep the "change"
water and meth
has anyone used there window washer box for water and meth setup and hot wired it with a toggle switch? I know kinda hilbilly but its worth a shot.
if so.....
what mix
where to inject
how long to inject
what performance will i get
THIS IS FOR SHORT TIME USE AND FOR TRACK ONLY NOT FOR STREET!!!!!!!!!!
Thanks,
Brice
Old Mar 24, 2009 | 01:32 AM
MBolivar's Avatar
if so.....
what mix
where to inject
how long to inject
Thanks,
Brice
Brice,
You could use the reservoir but you're gonna need more psi than what it is capable of pumping! 150 and 220 are the norm. Most guys do a 50/50 mix or if you're brave, play with those ratios and go more on the meth. Plumb it in the intake horn. I don't know the cycle duration but it will cool EGT's quite a bit. Hang on a bit as more guys chime in.
Old Mar 24, 2009 | 12:58 PM
what kinda cheep 152-200 psi pump could i get for cheep
Old Mar 24, 2009 | 02:25 PM
CamperAndy's Avatar
You are looking at $90 to $150 for a pump. Not sure if you consider that cheap.
Old Mar 24, 2009 | 03:12 PM
where at for 90.00?
Old Mar 24, 2009 | 03:30 PM
where at for 90.00?
i found a pump on ebay for 90.00 but i still need the injector???
so is it cheeper th just get the kit i can spend around 150.00-200.00
if i am lucky and i would like to have it up and running by this sat @ 6:00pm
for the track
Old Mar 24, 2009 | 05:03 PM
Don't do a toggle switch, use a pressure switch. Look through the switch book at your local NAPA or CarQuest and find one that switches on around 20 psi.
Old Mar 24, 2009 | 05:17 PM
CamperAndy's Avatar
for the track
Get a 150 psi Hobbs kit and it will have everything you need. You can get them complete for less then $200. Coolingmist has them for sure and I would guess Snow and Devils Own has them also.
Since Hobbs kits are not flow adjustable (you can set the on / off point) you may have to try different nozzles till you get what you want. For the application you are talking about, start small then work you way up in size on the nozzles till you get the flow you want.
Old Mar 24, 2009 | 11:47 PM
why is that?
Old Mar 24, 2009 | 11:49 PM
unless iam blind (witch i usualy am) coolingmist wants 260.00 is the cheepest i could find and about 550.00 for snows
Old Mar 25, 2009 | 12:30 AM
Alwaysworking's Avatar
alwaysonDTR
devils own is the cheapest i think
Old Mar 25, 2009 | 04:22 AM
CamperAndy's Avatar
The eBay stores are chaeper then their home web sites.
eBay Store for Coolingmist
Old Mar 25, 2009 | 03:31 PM
why is that?
Because if you turn it on too soon or forget to turn it off you will hydrolock the engine. A pressure switch makes it automatic for about the same price as a toggle.
Old Mar 26, 2009 | 12:06 AM
acs_beau's Avatar
What do you guys think of something like this? - http://cgi.ebay.com/ebaymotors/DODGE...Q5fAccessories
Old Mar 26, 2009 | 12:12 AM
when running the strip i am hitting about 28-30 psi of boost...........shift.......down to 12-15 psi then back up to 28-30 psi
so if i got a kit could i run meth at say 10-30 psi........ or could it lock
