water and meth
Old Mar 26, 2009 | 02:52 AM
65fury's Avatar
Originally Posted by acs_beau
What do you guys think of something like this? - http://cgi.ebay.com/ebaymotors/DODGE...Q5fAccessories
i checked out the store and there kits seem pretty cheap, infact they dont show a difference between the diesel kits or supercharged gasser kits other than price... even the parts are the same. $190 is pretty cheap for a W/M kit. plus they are using shurflo pumps... which i think is what everyone else uses.
jason
Old Mar 26, 2009 | 04:05 PM
bigbaddiesel416's Avatar
From: anderson commiefornia oh ya you can keep the "change"
jason
HEY THANKS I WILL HAVE TO DO IT NEXT WEEK THO TO LATE NOW FOR THIS SAT!
Old Mar 26, 2009 | 04:07 PM
Originally Posted by bigbaddiesel416
when running the strip i am hitting about 28-30 psi of boost...........shift.......down to 12-15 psi then back up to 28-30 psi
so if i got a kit could i run meth at say 10-30 psi........ or could it lock
wOULD THAT WORK
Old Mar 26, 2009 | 04:30 PM
Ace's Avatar
Ace
You'll be going through alot of water injecting it all the time if you're starting to spray as low as 10psi.
Old Mar 26, 2009 | 09:44 PM
i got a 55 gal drum of 100%meth and waters cheep so i dont care bout that it wont hurt anything tho doing it that low?
Old Mar 26, 2009 | 09:54 PM
If it's spraying while you are trying to shift the engine will stop.
If you can spray at 10 psi you are not spraying enough water/meth to be worth the trouble.
Old Mar 27, 2009 | 12:47 AM
so i need to spray at 15-20 psi just for the top end in 5th gear??
Old Mar 27, 2009 | 02:21 AM
CamperAndy's Avatar
You can spend more money and get a progressive controller for the pump and you can push a little at 10 psi up to a bunch at 30 psi boost. You can also tell it to dump a ton of water when you hit say 1250 EGT. There are a ton of different options out there.
Old Mar 27, 2009 | 09:47 AM
Ace's Avatar
Ace
Originally Posted by CamperAndy
You can spend more money and get a progressive controller....
That's definitely the best way to go for a work truck or really anything other than a dedicated sled puller.
Old Mar 27, 2009 | 02:36 PM
i have a ford f150 (ya ya i know) for the D.D. i drive the dodge once to twice a week and pull a little VERRY LITTLE other than iam workin on making it a 10.0 sec truck ( as the $$$ comes in ) the only reason i drive it is so the bat don't go dead and the engine don't go to crap so is the progressive worth the extra $$?
I found this today to aint it the truth...................
Due to the recent economic crisis, stock market crash, budget cuts, rising unemployment, unstable world conditions, the cost of insurance, electricity, petroleum, and taxes of all kinds, we regret to advise you that the Light at the End of the Tunnel has been turned off. We apologize for the inconvenience.
Sincerly,
The United States Goverment.
Old Mar 27, 2009 | 04:38 PM
CamperAndy's Avatar
99% of the time it would be for a daily driver.
Old Mar 27, 2009 | 05:38 PM
No, you want it to kick on at 20 psi in any gear. The pressure switch will stop the spray when you shift and then as soon as you build boost again it will restart.
Old Mar 27, 2009 | 10:43 PM
but spraying at 20psi is only giving you top end cooling (witch thats when its the hottest) but who runs around at 20 psi all day and iam done boosting at 28-30 and only see those #"s for 2-3 sec..... how much dose it help egt"s
and whats the progressive go for
Old Mar 28, 2009 | 08:46 AM
Ace's Avatar
Ace
Coolingmist is releasing a new model Varicool soon for around $200. I don't know what the other vendors like Snow, etc. have.
Old Mar 28, 2009 | 06:43 PM
Are you interested in water/meth for cooling or for performance? Your strategy should be dictated by your goal.
