water in fuel light on
ok i just replaced my fuel filter again to be on the safe side just incase there was more trash in the tank and this time the water in fuel light will not go off i am going to try pulling the bat wires to see if that will reset it if it does not is there any thing anyone can thing of
Make sure when installing that the little electrodes are DRY as any moisture will set off the WIF light.
Also. I had worn, almost frayed wires going to the sending unit. Could barely see them when on the motor but upon taking the unit out, I noticed it and that was causing me problems also. Some goop and electrical tape sealed them back up for another year.
Originally Posted by bgilbert
He's right. Don't touch the two electrodes when switching the sensor over to the new filter. As far as correcting it now...?? Might try removing the sensor 'on the filter on the truck'. (If the filter comes off, fine, then just remove the sensor with the filter 'off the truck'. Just trying to save ya a filter.) Then dry it off with a rag, then reinstalling. Then with the lift pump, refill the filter.
Water in Fuel Filter Light
If the filter is new most likley the spring inside the filter is touching the sensor tips. Take the sensor out and center the spring then test for continunity with a VOM. If you have continunity then the spring is still touching the sensor tips. Then fill with fresh fuel and install. Removing the battery connections will not reset the sensor.
I always test now because I ran into the same problem awhile back.
Jim
Jim
stratos201proxl
01-16-2014 11:04 AM
Joey-D
12-12-2011 12:52 PM
