Warmer Weather = Higher EGT ?????
Old Jun 23, 2009 | 10:16 PM
Power Ram 250 C's Avatar
Since about 2 weeks ago it seems like my egt will climb to 1200 degrees with a heavy foot running through the gears. I can't remember what the numbers were before this, but they were lower. I was wondering if the outside air temp really had that much to do with raising the egt that much. I'd hate to see me pull a trailer now. I might need to screw with my timing a little, sounds like I should advance it a little. What do you think? And, my air filter is clean.
Old Jun 23, 2009 | 10:20 PM
Yea warmer weather will do that... think about it... warmer air is now going into the engine.... Just like with a gas engine, they run better in the cold.. cold= more power
Advance the timing a little to lower egt's..
1200 is not much to worry about as long as its PRE turbo.
Old Jun 23, 2009 | 10:26 PM
The_Head's Avatar
As the air gets warmer it loses density, and oxygen. Your IP does not know this and still injects the same amount of fuel for a given psi... so EGT's will go up.
Old Jun 24, 2009 | 10:11 PM
What you guys are saying, makes sense. I'm pre-turbo. Thanks for the input; was about to get a little worried.
Old Jun 25, 2009 | 12:45 AM
jimbo486's Avatar
any motor, whether gas or diesel likes cold air. cold air is dense, thus, there are more oxygen molecules for the fuel to ignite with.
Old Jun 25, 2009 | 06:28 PM
DNRCustoms's Avatar
Ya I notice the same thing yesterday when it was 90 out, my cruise temp was up to around 800 pre turbo v/s 700 ish at about 70-72mph..
Old Jun 25, 2009 | 09:24 PM
14racing's Avatar
My non-ic doesn't hardy hit that towing a good load in this hot weather. Are you still running a stock down pipe? My truck benefited a lot from a 4" down pipe and a big air filter with no air box.
Old Jun 25, 2009 | 09:54 PM
I've got a 3.5" aftermarket dp going 3.5" all the way to the 5" stacks.
piney103
Apr 28, 2006 10:27 AM
BLKHO600
Jan 22, 2006 09:38 AM
jerry007
Oct 28, 2004 08:24 AM
dss667
Apr 11, 2004 06:24 PM
