W250, tire wear on one tire?
Old Dec 27, 2021 | 01:40 PM
bannerd's Avatar
Hey all, been to several alignment centers(five) and everyone keeps telling me the alignment is good. This is driving me nuts, on the right side outer most part of the tire I am getting wear. Does NOT happen on the other side.
This all started when I changed out my king pins upper and lower but that side had a shim, which I did keep in there. When I put a level too it with the shim on it was perfect. If I take the shim out it pushes the bubble to the outside of the vehicle. Which would cause the tire to wear on that outside edge.. so to counter that I kept the shim in. On jack stands and on a level floor it's level and I measured inner and outter base on tread front and back and I'm dead on. Typically I do get 1/16th of an inch but even that is pretty good.
I'm thinking about just taking the shim out, is this normal from factory? One of the alignment members mention axle warp but I'm pretty sure I would feel something. It drives good down the road and if you let off the steering wheel it pulls to the right. Almost thinking about buying this quick trick system.. I've spent so much in the last two weeks and now I need one tire.. HA
Old Dec 29, 2021 | 12:42 PM
jerseybud's Avatar
a shim like in the upper king pin spring to increase pre-load? or a sim somewhere else like on the spindle? Might want to get a dial indicator guage and check the rim run-out, rotor runout and I would also look into tire as some off brands do some wonky things. I'm assuming no lift?
Old Dec 29, 2021 | 01:22 PM
brcron007's Avatar
Its your king pin is worn. Pull the cap and look at the outer edge of the cup on the side and you will see it has worn down thinner than the opposing side.
This is indication that the pin itself is worn and should be replaced. OR you can do like others and just change the cup and the issue will crop back in a short time.
Good luck !
Old Dec 31, 2021 | 05:52 AM
KRB's Avatar
KRB
But he stated that it was fine UNTIL he replaced his king pins.
My front right tire was wearing the same way until I changed out the king pin. Didn't have a shim though, that I recall.
Old Jan 4, 2022 | 12:45 PM
bannerd's Avatar
yeah the shim is right on the knuckle. I'm going to take it off, set the rig back down and see if it's level on a level floor. I need new tires anyways (trying to find a good brand) so I want to get it right before I put those things on.
Old Jan 5, 2022 | 12:15 AM
KRB's Avatar
KRB
I'm needing tires as well - at least after I do the driver's king pin. I'll look at Toyo and Coopers first and see if I can find them in the proper size and load range. I have them on my Jeeps and have been very impressed with both.
Old Jan 6, 2022 | 04:22 PM
Have you tried swapping the front tires/rims side to side or to the back and see if the problem follows?
Old Jan 7, 2022 | 09:01 AM
bannerd's Avatar
yeah it does follow if I move the back tire up. Run out is good and the tire for the rotor, wheel. There is also a very thin shim about 1/4” thick. I didn’t notice this... should that go too? I’ll needle air it off if so. The other side has non of this but I wonder if that will mess up my steering bar alignment.
Old Jan 7, 2022 | 03:18 PM
u2slow's Avatar
What is this 1/4" shim shimming?
What does the shop alignment sheet say for camber and caster? (actual values)
I really encourage you to get a handle on doing your own alignments for this truck. There's only one adjustment on these trucks that an average shop is doing anyway (toe). The others need hard parts and/or creative solutions that aren't part of a normal alignment job.
Old Jan 10, 2022 | 07:49 AM
bannerd's Avatar
Have not taken this apart yet, been too dang cold! Tonight is suppose to be -35F.. yippee.
Anyone know of any good tire brands? Looking for something aggressive as I do forestry and some spots are a bit muddy. I might just get the same brand I have now, been a good tire.
https://www.falkentire.com/tires/lig...eak-m/t-tire-0
Old Jan 10, 2022 | 04:45 PM
u2slow's Avatar
I've been a Goodyear fan for the last 12 years or so - Duratracs being the latest. Also being used by the forestry company my buddy works for. (Toyo M55 is use there also.)
Between the sizes myself a few friends run, the lower weight capacities seem to wear faster - probably softer compound.
Old Jan 11, 2022 | 04:57 AM
KRB's Avatar
KRB
I'm old school and LOVE the 7.50X16 Grip Spurs on my M880 (W200) and 9.00X16 Power Kings on my B3 but know they aren't practical for a newer vehicle that does highway time.
My XJ has Open Country A/T III | The All-Terrain Tires for Trucks, SUVs and CUVs | Toyo Tires and my KJ has Cooper® Discoverer® AT3 4S™: All-Terrain Tire | Cooper Tire. Neither are very aggressive but spend most of their time on pavement. Excellent in snow, probably not so much in deep mud but they do fine on the farm and hunting roads/trails.
I've been looking for a good aggressive affordable mud tire to replace the wornout, bias Grip Spurs on my W200. I think one can find two out of those three but not all three in one tire...
Old Jan 11, 2022 | 05:05 AM
KRB's Avatar
KRB
Do you know between the Duratracs and M55s which they prefer? The M55 looks pretty good on paper and can get in an E load range.
Old Jan 11, 2022 | 03:36 PM
u2slow's Avatar
I don't know which they prefer.
I know from my experience the duratrac has more siping and better in wet/ice/snow. I have them in load E. The M55 is harder, and wears longer on sharp gravel road; it also gets loud/droney the last 50% of its life.
Enri1993
Aug 7, 2016 04:58 PM
DaNuGuy
16
Jun 25, 2012 10:35 AM
ramman21921
Oct 12, 2003 09:36 PM
tgleason
Sep 18, 2003 09:49 AM
thatguy
Feb 14, 2003 02:12 PM
