Voltage Regulator
Old Sep 21, 2022 | 07:52 PM
91.5CTDBanks's Avatar
Voltage Regulator
Truck is a 1991.5 CTD. The truck system is not charging. Alternator is good. Can I check the voltage regulator on the fire wall?
Thanks
Old Sep 23, 2022 | 09:05 AM
nonrev's Avatar
10 Year Member
The voltage regulators on these trucks a notoriously bad and if you change it get a genuine Mopar not aftermarket, then run your signal wire direct form the battery though a relay to get true battery voltage to the regulator, and don't forget to put a ground on the regulator as well
Old Sep 25, 2022 | 08:36 AM
Ok, how do I find a real Mopar one these days?
Old Sep 25, 2022 | 10:28 AM
nonrev's Avatar
10 Year Member
I googled it and went to moparpartsgiant.com and the number you are looking for is 5324625
Old Sep 26, 2022 | 07:04 PM
Well, 5324625 as a part number did not work. 5234625 does. Looks like fleabay has some genuine VR's as well as moparpartsgiant.
https://www.ebay.com/itm/26542944680...Bk9SR6yTtaPvYA
Old Sep 27, 2022 | 06:45 AM
nonrev's Avatar
10 Year Member
Sorry about that, I know I need to proofread before hitting reply
Old Sep 27, 2022 | 08:26 AM
cougar's Avatar
I gave up on short lived VR's and constant wiring issues and went with a 1 wire alternator. Never happier.
Old Oct 8, 2022 | 11:11 AM
haily grace's Avatar
you can find it on ebay I think
TurboAZ
Aug 27, 2013 09:26 PM
9MM
Nov 5, 2011 11:26 AM
DieselDodd
Nov 22, 2009 09:36 AM
mandtandk
Jan 31, 2009 11:14 AM
CruisingRam
Feb 19, 2008 09:55 AM
