Who has rewired in a voltage regulator on thier charging system?
My truck has been down for about 5 days now- and I need to get it moving- the altenator is puting out, but no charging at the battery, and I understand that some folks here have wired in an older style voltage regulator- anyone have details on this?
I am immobile right now, and my mopar is my only form of transportation for my family!
I've done this to three trucks, works great.
Just disconnect the two small wires to the alternator and tape to keep them from shorting. Two wires from the new regulator are interchangeable. Top regulator terminal must go to a switched positive.
Right on dude- thanks so much!
Am I asking too much if you have an underhood pic of this set up?
Also that looks like the generic mopar voltage regulator, any help on what years and off what so I can source it locally please?
I would like to get one at Napa if I can!
I checked the 140amp fuse in the underhood fuse box, if that is what you mean? I have been through these wires, and haven't found a fusible link you are talking about, if it is different?
If you alt is putting out then the PCM and voltage regulator is working. Take it to a starter altenator shop and get it fixed and be done with it. Surely there is a shop that qualifies even in Anchorage.
At any rate, with the key "off", check for power at the big charge terminal on the back of the alternator. If the charge circuit is complete to the battery as it should be, you will have power there.
Any 12 volt regulator will work, old style relay type or solid state. In fact I've heard the number of the one in my picture (not really mine) above isn't good.
Here's where I got the picture and more instructions https://www.dieseltruckresource.com/...n&onlynewfaq=1
CruisingRam
Aug 10, 2004 10:10 PM
