Ve pump is leaking fuel!
Old Apr 19, 2015 | 01:32 AM
Alex Lochner's Avatar
It's dripping a lot from the spring beneath the throttle control of it is just a bushing or o ring that needs replaced on the throttle shaft where do I get replacements and how do I get the top on of the pump off?!? Advice and directions are very helpful I have to have it good to go in a couple days! 1992 12 valve 174k miles
Old Apr 19, 2015 | 07:29 AM
After living w hat you're dealing with, I would suggest you 're seal the whole pump. One bad. O ring on a 22 year old ve pump is a sign that all the seals are going bad. You could just repair the offending o ring, but you'll be back at another that's waiting to let go.
I had no place to do the re seal myself, so I paid a shop to do it for me. The rebuild / reveal job you ask about is in the sticky, I believe
Old Apr 20, 2015 | 12:43 PM
gyman98's Avatar
There's a bronze bushing and a o ring on the shaft. Replace both, the bushing pressed into the top. I would buy a reseal kit and do every seal you come across while you have the top off. Make sure to note your throttle index marks when you pull the linkage off
Old Apr 21, 2015 | 09:52 AM
sooty's Avatar
also consider doing the governor spring rpm upgrade while your right there, check the sticky
Old Apr 21, 2015 | 10:24 AM
kensmachine's Avatar
The stock bushings are bronze its best to replace it with a new bosch one that are harden steel ken
Buc4x
Apr 7, 2013 04:22 AM
jesussaves
Jun 28, 2012 01:36 PM
lilsuzuki4x4
Sep 1, 2011 01:50 AM
jared thompson
14
May 10, 2011 12:23 AM
sawboywv1
14
Feb 18, 2005 04:11 PM
