ve pump ?
Old Feb 8, 2009 | 07:52 PM
cb_boxman's Avatar
ve pump ?
How do I change the fuel shut off to a mechanical cable pull type on a 93 W 250
Old Feb 8, 2009 | 07:58 PM
Look in the sticky, theres a write up on it.
Old Feb 8, 2009 | 08:40 PM
peobryant's Avatar
Any particular reason you want to do it?
Old Feb 8, 2009 | 08:55 PM
cb_boxman's Avatar
if i hit a bump in the road the truck dies wiggel the wires and it will start and go again
Old Feb 8, 2009 | 08:56 PM
cb_boxman's Avatar
Do I have to Pull out the shut off solenoid to make this work or gut it?
Old Feb 8, 2009 | 08:57 PM
peobryant's Avatar
Gut it, but leave it in place.
Old Feb 8, 2009 | 09:00 PM
cb_boxman's Avatar
cool thanks guys And also if i turn the fuel screw in is that all i have to do to get a little more out off this old truck
Old Feb 8, 2009 | 09:20 PM
peobryant's Avatar
Itrongly suggest getting gauges before you add any more fuel. At least a pyro, but boost is good to keep up with. If you have an auto I would also suggest a tranny temp. gauge. When you start adding more fuel, you may want to invest in a fuel pressure gauge as well.
Now to the actual question, yes, turn the fuel screw to get some more power from the truck. You may also want to check for full throttle travel.
Old Feb 9, 2009 | 02:27 PM
Replace the crappy spade connectors with a ring terminal and you will never have that problem again. Even cheaper than a pull cable.
Old Feb 10, 2009 | 11:56 AM
cb_boxman's Avatar
Thanks guys for the info went with the cable i had on hand no more problem
powerwagon440
May 25, 2003 02:31 PM
Puke
May 22, 2003 12:18 AM
amartinson
0
May 4, 2003 01:55 PM
TPilaske
16
Nov 22, 2002 08:15 PM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
