VE governor spring access
Old Mar 19, 2005 | 08:16 PM
BC847's Avatar
1st Generation Admin
Question VE governor spring access
In reading the 3200 RPM Gov Spring Installation Instructions as found in these forums FAQ, it starts off talking about having to loosen the pump and rotate it toward the fender.
Is this done to allow access to the two Allen bolts on the engine side of the pump top? Are we trying to get out from under the head's flange so as to get to the bolts?
Do I really need to do that to get to the governor spring in this case?
Old Mar 19, 2005 | 08:25 PM
It's a lot easier to work on the idle screw with the pump retarded. Just make a match mark so you can put the pump back where it was, you won't regret having more space to work with.
A little tip the directions don't give: run the high and low idle screws in to clear the pump top screws instead of backing them all the way out. Also pull off the throttle arm as early as possible, and take the throttle cable bracket down for better access at the back of the pump.
Old Mar 20, 2005 | 10:32 AM
rebal's Avatar
tip... i bough a long T handle allen 5mm with a ball end on it ti get to the back screw so i didnt need to move the pump. and like wannadiesel said take the throttle bracket off it makes lots of room ...when i did mine the the throttle arm came off in one piece so make sure you dissasemble it 1 piece at a time to verify the index marks .mine like most was set at 10 and 4. one more thing just my pref. I have a flat blade screw driver thats 5/16x 18" long and that sucker gets to the idle screw from behide the throttle bracket just need to leave off the afc air sup. tube to do the ajustment. hope this helps
Robert
Old Mar 20, 2005 | 02:08 PM
edwinsmith's Avatar
In the pic, what's that big square plastic thing with the plug on top of the pump? My 98 doesn't have that.
Edwin
Old Mar 20, 2005 | 02:41 PM
Redleg's Avatar
We don't have overdrive, so we don't have one. It's the throttle position sensor.
Old Mar 20, 2005 | 02:43 PM
Den's Avatar
Den
I'm installing my spring right now. Everything is apart and i'm taking tons of pics.
Didn't rotate the pump either. Grabbed a 5mm allen and cut the long leg. Fits down under the AFC and you can turn it with the rigged up wrench and screwdrver T handle
I downloaded the install steps from here. They are in a wacky order that's for sure.
Den
Old Mar 20, 2005 | 05:27 PM
Blowndodge's Avatar
Good luck Den! I anxiously await how it went. Fill us in!
Brad
92smokin blacky
Oct 3, 2010 07:21 AM
Monty
Apr 1, 2003 02:15 AM
dieselcrazy
Mar 27, 2003 11:06 PM
Alec
Feb 5, 2003 06:23 AM
dieselinveins
Nov 15, 2002 10:36 PM
