Valve cover spacers for head studs...
Came across these being sold on E-bay....Auction # 121754070458
Thought it was a potentially neat solution to having your valve covers machined.
I just can't figure where you place them? Under the seal on the head...not likely since it would probably weep oil. But inside the valve cover gasket, then your valve cover goes on top? Then the washers would go on top of the rocker stand, under the valve cover?
Good idea, (if no leaks down the road) but for just a day or two and a tad more cash supporting your local machinist, you can have it done right by milling the pedestals. I'm still glad I machined mine after seeing this invention, just my .02.
Is there a reason why guys are not using the Haisley head studs? Just curious as I am goin to do studs this summer. Seems kind of a wash.. $430 for ARP studs/$80 spacers or machining rockers $? or the Haisley studs $490 and some grinding on the valve covers.
Stu
Stu
Last time I had my rocker ped's milled it was $100. Would still do it again for the $20 difference as the point of milling the pedestals down is to increase the stud thread length. Without doing it the tensile strength of the bolt exceeds the shear strength of the threads
4969joes
Apr 11, 2010 06:55 PM
jmccart
21
May 14, 2007 11:47 AM
West Coast
Nov 6, 2006 07:53 PM
