valve cover seals, valves adjusted
i got a few questions
1.where do i get new valve cover seals because mine are leaking oil.
and is it something i can do my self.
2.how much does it cause to get my valves adjusted
and thanks to the people that helped me figure out what was wrong with my injector pump
1- The best place to get the gaskets is Cummins. Tell them you want the gray ones. It is very easy to do, just one bolt per cover.
2- If you have the valve covers off, you might as well adjust the valves. It's very easy to do and requires no special tools. A little reading:http://dodgeram.org/tech/dsl/valve_adj/12_valve.html
The methods down at the bottom are fine. You don't need to monkey around with the timing pin or any of the special tools they show. Basic hand tools and a set of feeler gauges is all you'll need.
Unless your's are torn or leaking you really don't need to replace your gaskets. Especially if you have the gray ones. They are meant to be reused. All you need is a feeler gauge a screwdriver and a couple of wrenches.
Edwin
Edwin
Originally Posted by 440forPOWER
Just curious is there any online cummins dealers that are good to work with. I too am about ready to set my valves. But I need a valve cover gasket and dont have any local cummins dealers. THANKS
http://www.cummins.com/cmi/content.j...menuIndex=none
Use the map to find the nearest Cummins distributor, call them up, and you will have parts in a couple days.
sabreson
16
Jan 25, 2010 01:06 PM
cjthor
Dec 23, 2008 09:58 AM
