Valve adjustment and fuel mileage
Old Mar 9, 2006 | 12:08 AM
dodge250's Avatar
i am fairly new to cummins and diesel engines, i get about 12 MPG arround town and freeway. i bought the truck about 4 months ago and the owner never mentioned anything about the last time he adjusted the valves, a freind said it sounded like they needed to be done. just wondering but, if the valves havent been touched in a while would that cause fuel mileage to suffer?
also, i recently discovered a boost leak, i know this can have an effect on fuel mileage as well, however it never leaked when i bought the truck and now that it is leaking, fuel mileage hasnt changed. it is leaking out of the joint where the turbo and the aluminum elbow connect(intercooled). i pulled the clamp off and found that the flat o-ring was cracked. so thats where its leaking from but does anyone know where i can find this o-ring. i went to the dealership and they said dodge discontinued that part #. so i went to lowes, home depot, ace, auto zone, kragen and osh. no one had it. any ideas?
Old Mar 9, 2006 | 03:00 AM
Bushy's Avatar
Patron Saint of 1st gens
That o-ring failing is fairly common. You just need to get to a dealer that has those sorts of parts.
I know PDR has them, or if not they can get them I would think.
I'm not certain if you need to go to a Cummins dealer or a Holset dealer to get that thing.
pb....
Old Mar 9, 2006 | 12:54 PM
tboling's Avatar
Your Dodge dealer is pulling your leg. The oring is steal offered by dodge,and pdr dose have them. Your vales being out off adjustment,can make your fuel mileage drop. I adjust my vales ever 10,000 miles cummins says every 20,000. Check your vales! Your Egt's will also be higher and your engine will be under powered, and start harded when the vale's are out of adjustment.
Old Mar 9, 2006 | 02:19 PM
bigragu's Avatar
O-Ring
Just replaced mine a month ago. Got it from Cummins dealer. They are yellow now. Price: $18.00 bucks!!! Crazy, huh?! I'd hate to think what a Dodge dealer would want-buying straight thru Cummins has always been cheaper for me. Carmyne
Old Mar 9, 2006 | 09:04 PM
nailhead's Avatar
How complicated a process is valve adjustment on these engines? I would like to adjust the valves on mine (and have on a range of vehicles from BMW motorcycles to Landcruisers), but I don't want to have to buy a bunch of factory tools to do it.
Got a Case VAC, too...
- Chris
Old Mar 9, 2006 | 10:20 PM
Underpsi's Avatar
- Chris
The only tool that is somewhat uncommon to adjust the valves is a feeler gauge and you can easily get one from a parts place for $10
Old Mar 10, 2006 | 12:17 AM
dodge250's Avatar
i imagine it is easy, just time consuming. thanks for the help guys i will locate the cummins dealer and get that o ring, then adjust the valves and see what happens. by the way my egts get pretty high and get there fast.
Old Mar 10, 2006 | 09:06 AM
nailhead's Avatar
Got that-- I was thinking of stuff like TDC locating tools, or the paraphernalia needed for a shim-&-bucket valve adjustment. Thanks for the info!
- Chris
Old Mar 10, 2006 | 10:53 AM
Underpsi's Avatar
- Chris
You can use the timing pin which is located under the injection pump to get it at TDC
Old Mar 10, 2006 | 01:44 PM
nailhead's Avatar
It's already there, or that's where it goes after I get one?
- Chris
Old Mar 10, 2006 | 02:21 PM
Underpsi's Avatar
its already there from factory
Fishbait
Nov 23, 2009 11:21 AM
ConnerCop
May 5, 2009 07:48 AM
dhughe2
13
Dec 6, 2006 07:40 AM
CmminsBeast
Sep 4, 2005 02:03 AM
2500TurboDodge
Jul 11, 2005 10:52 PM
