Vacuum Routing
Old Apr 4, 2012 | 07:37 AM
1972RedNeck's Avatar
Vacuum Routing
On Saturday I drove down to salt lake to look at a 1993 3/4 4X4 cummins. It happened to follow me all the way back to Montana.
The only thing that I have found that needs any attention is the heater box doors. The air is stuck on the head vents. It does not change to foot or defrost. There is a vacuum diaphragm on the left end of the heater box. the diaphragm is good. There is no vacuum no matter where you move the lever/which button you push.
There is a line going from the pump to the brake booster, a smaller line going back along the main line, and then a tiny line goes from the center of the the plug in the booster. The vacuum pump works.
What do I need to do?
Old Apr 4, 2012 | 08:29 AM
Buddy Stewert's Avatar
Heater box has two cables I think if you pull the glove box out you may see them.
Old Apr 4, 2012 | 08:51 AM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
There is a multi colored clear headed plug behind the radio that distributes all the vac to the various gates. Make sure that didn't unplug.
Old Apr 4, 2012 | 01:44 PM
bannerd's Avatar
I'm curious about this.. if you get it working can you throw some pictures up? Mine only does defrost..
jimbo486
May 8, 2016 06:07 PM
kd460
Feb 16, 2004 09:49 AM
surfram
Feb 12, 2004 07:20 AM
SilverDiesel
Jan 1, 2004 03:14 AM
