Fuel leaking from fuel shut off solenoid
I have searched through the forums with no luck, my truck is leaking fuel around the fuel shut off solenoid. I replaced this soleniod about 2 weeks ago as the truck would periodically would not shut off. Fixed the problem for about a week now it will not shut off period. I was using the manual shut down lever and was content with that for a while. Then I began to notice a fuel leak it was leaking around the throttle shaft. I have a Denny T AFC delete, I took the top off replaced the o-ring on the throttle shaft, that part of the leak is fixed. Then I got it back together, started it and noticed is was leaking a fair amount of fuel around the fuel shut off solenoid. I took is out reaplaced the o-ring and did not make a bit of difference. Also I must have not gotten the manual lever in there quite right because the truck has to be stalled now to shut it down. Any ideas?
randyswelding
Feb 9, 2009 10:40 PM
skywalker175
May 13, 2003 02:37 PM
