>>> Turbo Oil Line ??? <<<
Old Aug 29, 2010 | 09:41 PM
BearKiller's Avatar
Question >>> Turbo Oil Line ??? <<<
I need a little info on the original issue 1989 Dodge/Cummins oil feed line that carries oil from the top of the filter bracket to the top of the turbo; braided stainless line.
At the filter bracket end of this line, there are two hex-nut fittings, both accept a 5/8" line-wrench.
Between these two "nuts" is a slender tube of about an inch or so long.
Then there is an adapter fitting that actually screws rigid into the filter bracket.
Is the reason for the two "nuts" because the top one is sort of a swivel, allowing the braided hose to be oriented; or, can the upper portion be screwed loose from the lower ??
The reason I ask is because I turned the upper "nut" a whole bunch and at first it seemed to come apart at that point; then, I moved the wrench to the lower "nut" and the whole thing un-screwed right out of the adapter in short order.
I sort of think it is a swivel, but I am uncertain.
Thanks.
Old Aug 29, 2010 | 09:44 PM
dieselJon's Avatar
I don't know bearkiller. I did the same thing but never got the lower one off the upper one to see if it swiveled.I replaced it with a small hydraulic hose from O'Reillys. Cost me something like $15 but that was 4 years ago.
Old Aug 30, 2010 | 07:23 PM
Yes, there's a swivel.
Old Aug 30, 2010 | 07:30 PM
BearKiller's Avatar
Thanks; one more mystery solved.
Old Aug 30, 2010 | 07:43 PM
Just call me Nancy Drew.
pistazie
ABDTR #5
Apr 30, 2009 08:16 AM
Bobcat698
Jul 23, 2006 05:29 PM
charger 69
Jun 2, 2006 02:04 AM
jazz_kt
Aug 5, 2005 11:51 PM
banks twinram
Jan 4, 2005 04:27 PM
