time slip & pictures
Old Aug 28, 2010 | 06:22 PM
sshort's Avatar
I have pictures & time slip in my gallery but i don't no how to get them on a thread could some one help
Old Aug 28, 2010 | 06:30 PM
madhat's Avatar
Administrator/Jarhead
Click on the picture, then look for the bar that says BB code. Copy it and paste it here.
Need to work on that 60 ft time, you'll get close to the 12's
Old Aug 28, 2010 | 06:31 PM
sshort's Avatar
thanks i just found it in the sticky i will try it yes i am running street tires & a open rear end comming out slow so i dont spin the tires
Old Aug 28, 2010 | 10:58 PM
Sweet time man.
How'd you get 3.07 gears in a Dana 80 ?
Old Aug 29, 2010 | 12:34 PM
sshort's Avatar
they come stock with them with a 3speed 727
Old Aug 29, 2010 | 12:40 PM
towriggity's Avatar
You aint gotta dana 80 then. Dana 70 is what you have
Old Aug 29, 2010 | 12:44 PM
sshort's Avatar
no i have a one ton dully with a Dana 80 & 3.07 gears Also have a another Dana 80 with 3.54 gears the 3.07 gear will not fit in the 3.54 housing believe me i tried
Old Aug 29, 2010 | 12:47 PM
sshort's Avatar
Old Aug 29, 2010 | 12:50 PM
sshort's Avatar
Old Aug 29, 2010 | 12:51 PM
sshort's Avatar
sorry I just found out how to post pictures
Old Aug 29, 2010 | 01:33 PM
What-ever...
Old Aug 29, 2010 | 01:39 PM
Free89W350's Avatar
UMM OK Your truck came stock with a Dana 80??? If so you have one rare piece of equipment there. I would stop driving it immediately and put it in a temperature controlled moisture sealed container and never touch it again. But thats just me
Old Aug 29, 2010 | 03:41 PM
Onemoparnut's Avatar
3.07 is not a dana 80 ratio. what you have is actually a dana 71 with 3.07 gears that is what that truck had from the factory. The 80 wasnt used till 1994 when they changed body styles. Some one may have swapped a 80 in your truck but then it cannot have 3.07 ratio.
Old Aug 29, 2010 | 04:51 PM
sshort's Avatar
Ive made a grave error I Just checked all 3 of my rear ends & you are right it is a dana 71 I not sure what I was thinking there but thanks for straighting me up but I do have a spare set of 3.07 the ring gear is approx 10.3/8 in diamter
Old Aug 29, 2010 | 06:26 PM
towriggity's Avatar
what size tip is that? 7 or 8"
