Turbo oil line
Old Jun 1, 2006 | 02:30 PM
charger 69's Avatar
Question Turbo oil line
I started to change out the 21 cm. turbo housing and I can't remove the oil line without twisting it.Does either end have a floating nut like a brake line?if it does this one has fused together.Any ideas? Thanks
Old Jun 1, 2006 | 02:38 PM
flashgordon's Avatar
Need 2 wrenchs, on for that adaper that gos in the housing and, one for the line.
Old Jun 1, 2006 | 02:45 PM
charger 69's Avatar
Ive got the fitting in the housing loose.If I hold that fitting I can't turn the oil line out without twisting it as the fitting on the line doesn't turn.
Old Jun 1, 2006 | 03:45 PM
I gess you could undo it for the oil filter hosing and then spin the hole assambled hose out of the turbo?....some one over torked that nut! It has a o-ring in it and only needs to be snugged to seal
Old Jun 1, 2006 | 04:01 PM
Falcon1's Avatar
Ya what he said
Old Jun 1, 2006 | 04:04 PM
Sorry i didn't read you first post very well ....yes the bradded line nut is what floats or turns on both sides so if it wont come off the turbo than you can take it of the oil filter housing side!
Hope that made better sence!
Old Jun 1, 2006 | 04:47 PM
charger 69's Avatar
Gotcha,thats what I needed to know.It kinda looks like a curved AN fitting so I wasn't sure if the flexable line had to come off to get the fitting out.
Old Jun 2, 2006 | 02:04 AM
bgilbert's Avatar
It's metric. One big wrench to hold the adaptor in the turbo, a smaller wrench on the nut on the turbo hose, another wrench to hold the hose from twisting.
pistazie
ABDTR #5
Apr 30, 2009 08:16 AM
Common
Sep 14, 2006 05:44 PM
Bobcat698
Jul 23, 2006 05:29 PM
jazz_kt
Aug 5, 2005 11:51 PM
banks twinram
Jan 4, 2005 04:27 PM
