turbo oil drain tube, will permatex work?
Old Apr 23, 2007 | 04:21 PM
Cowboy_Customs's Avatar
Ok, so I am REAL immpatient. I called every dodge dealer around and NO one has the stinkin gasket, gunna be several days waiting. Will permatex or some kind of "liquid" gasket subside for a while?
Im dying to get that WH1C mounted up!!
Old Apr 23, 2007 | 04:27 PM
Make sure the surfaces are clean and use it sparingly. Get the copper stuff, it's for high temp areas.
Old Apr 23, 2007 | 04:30 PM
Ilikebikes's Avatar
Sweet, let me know if it works. I'm gonna use the spare tube I have to drain my BHT3B and I know that sourcing gaskets and stuff is a real pain!
Old Apr 23, 2007 | 04:35 PM
If you are going to use the stuff, use a real thin bead (cut just the very tip off the nozzle) and let it skin over before you put the parts together. A piece of RTV in a piston cooling nozzle could ruin your day.
Old Apr 23, 2007 | 04:56 PM
ahh, thanks dave! That being said, Im goin to the barn! WH1C commin right up!!
I immagine something stuck in a nozzle somewhere could make for a VERY bad day. Thanks!
I'll let ya know what I come up with Ilikebikes!
The gasket is easy to get ahold of if yer patient. Which was not a programmed trait of mine. I have one comming but I just cant stand the tension thats mounting.
I guess watching cummins pullin and drag videos arnt helping matters either
Old Apr 23, 2007 | 11:31 PM
edwinsmith's Avatar
Go to a local farm supply or autoparts house and get some gray paper gasket material and make your own gasket. This is what I did for both the oil drain and the air intake. Works fine. No sealer needed.
Edwin
Old Apr 24, 2007 | 06:44 PM
dpuckett's Avatar
I have used anaerobic gasket maker for the last 3 or 4 turbo swaps I have done. No leaks thus far, and it sets up almost immediately.
Daniel
Old Apr 25, 2007 | 11:59 AM
Well I got it all together yesterday. The permatex blue RTV or what ever it is, is a temporary solution. Its leaking, or was. I havent checked it today, I allowed it to set up for a few minutes before assembly, then still allowed it to do its thing while I fought with the bolt on the engine side for the drain tube. and the rest of assembly. My gasket is in now, so I gotta go get it. oh well, Itt did what i wanted it to do, Temp. solution.
barngal6
Feb 7, 2009 06:21 PM
billmac
Nov 9, 2008 01:33 PM
Dean Snow
Sep 21, 2007 01:18 PM
90dodge
Jul 26, 2006 07:33 PM
KATOOM
May 2, 2003 05:19 AM
