Turbo or Intercooler
Flash.
I would go ahead and invest in a dial micrometer and associated mount so as to be able to set the IP timing dead-on. With that fueling, I think I'd start at 1.9mm. I think 2.00 would be about right.
I don't know the MAP of that turbo set-up but I have all ideas you're at the bleeding edge of it and are getting more superheat than a larger, less maxed turbo could offer with the same drive.
Make the wastegate operable to start as that will greatly help limit the superheating.
The Gillett stage II is the same as a HTT stage III set up. I've heard that any boost over 30 psi is hot; should I set my wg lower? Where can I get that set up to time the pump?
Thanks
Thanks
Doing a quick search on Ebay . . . . .
Here's the basic mount (use your 8mm diameter shank micrometer) ~ http://cgi.ebay.com/VW-Audi-Bosch-di...QQcmdZViewItem
Hope this helps.
92smokin blacky
Jan 14, 2010 09:23 AM
6Stix
Feb 13, 2009 08:32 AM
mullishacrew
Oct 30, 2008 09:29 PM
CrazyKracka
Aug 9, 2004 10:16 PM
