Turbo Boost PSI
Old Apr 19, 2012 | 08:01 PM
Buddy Stewert's Avatar
Turbo Boost PSI
What should the boost go up to on a stock 1993, 5.9 with a 5speed.
I'm seeing 19 PSI most in my empty truck.
Is that right.
Old Apr 19, 2012 | 08:57 PM
dieselJon's Avatar
Yep. Between 16-19 on a stock IC'd truck that is not leaking.
Old Apr 19, 2012 | 10:28 PM
Jklawinsky's Avatar
Sounds spot on.
Old Apr 19, 2012 | 10:57 PM
Ok Great Thanks.
Going to do some up grades wanted to have a base line to go from.
To start with
4 inch exhaust, 16mm housing.
Old Apr 19, 2012 | 11:50 PM
bobva's Avatar
16mm is not much if any improvement on a 93 which has a 18.5 housing.
16mm on a 92 which is a 22mm housing will be a improvement
4 inch full exhaust is also not much if not a loss with the 16 18.5 or 22mm housings.
The exhaust flows out of the housing to fast ( no pressure ) to keep the compressor side spinning = lag.
Leave the 3" down pipe then open it to 4'' if needed.
Old Apr 20, 2012 | 05:57 AM
dieselJon's Avatar
No pressure is good. All the exhaust goes past the vanes and spins it regardless.
Old Apr 24, 2012 | 06:41 PM
Picked up 4 LB of boost with the new 4" Exhaust.
Old Apr 24, 2012 | 11:44 PM
JQmile's Avatar
Crazy! Google "Project Rust bucket"...I made 301rwhp with mostly stock stuff.
38 Cigarette
16
Aug 28, 2015 11:27 PM
nrussell
Jul 23, 2008 08:58 PM
Tommy93w350
Aug 7, 2007 12:15 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
ckennedy
Sep 29, 2004 05:06 PM
