Turbo?!?!?!?!?
Get one of the turbos i posted links to and put a wastegate on it at like 42 psi.
He only has 1200$ so he can't get a big big variant custom S300.
PDR hx40 should be fine for you.
an HX35/12 won't even come close to supplying enough air for 6x.016 injectors and be able to tow.
i don't know about the aFC lever though....
An HX-40/16 supposedly spools a tiny better or same then a stock H1C with a 18cm.
You have 1200$ so I'd buy a peirsdiesel PDR HX40/16, they customize it to make it spool up quicker and its the newer style HX40 with the 7 blade compressor.
I think a member on here has a PDR HX40/16 and he put down just over 400HP with it on stock NON i/c injectors.
With a stout torque converter you should be able to put down 400hp + if you spend some time tuning it. 6x16's and a MODDED hx40 should have no troubles laying down 400HP if the power is getting to the ground.
Are you still running the stock lagmaster exh. housing 89f150?
quite a bit moreHX40 can support around 400Hp i'd say. It may get a little hot though.
Can't you up your budget to $1500?
Your stocker is a 56/60/21
PDR HX40 is a 60/65/16 with mods of course making it $1200
[QUOTE=
[/QUOTE]
If you're thinking of gearjammer91, he also had w/m. I agree with everyone who's suggesting a 62/71, you could probably find a used one for 1200. Search fleabay.
[/QUOTE]
I disregard everything i said in this thread about gettting a turbo.
Go get yourself a Goerend, or DTT converter first. $700 at most.
THEN get a turbo. If you add a bigger turbo your going to make your converter worse and you probably won't feel much extra power.
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
