truck up and died tonight
Old Jan 6, 2006 | 01:45 AM
timb's Avatar
Was headed to town tonight and the old girl shut down just like a gasser would if you turned off the key.pulled off the road and started doing some looking around. there is no shut off solenoid in my truck, so that was not the problem. there was plenty of fuel at the fuel filter so the new fuel pump was good. got a wrench out of the back of the truck and broke loose # 1 and 2 fuel lines at the injectors and there was fuel there when we cranked her over but she still wouldnt fire. broke 3 and 4 loose and fuel came out and she fired up, but ran real rough. tightened the lines down and fired her up and brought her up above an idle for a few seconds and she smoothed out and ran good. now the only thing that I can think of is maybe a piece of the 2 fuel shut off plunger tips that got pulled off could have gotten pulled into an area of the pump that would cause this. has anyone else had this happen.
Old Jan 6, 2006 | 05:39 PM
I think you should replace the fuel hoses.
Old Jan 7, 2006 | 02:45 AM
timb's Avatar
Do you suppose that I pulled some air in from somewhere Dave.I really could'nt think of where a piece of rubber could plug off the inside of the i.p.
Old Jan 7, 2006 | 07:05 AM
Yeah, I think it's air. Cracking the lines got 'er fired right back up. It's pretty common on the older trucks to have fuel line problems.
Old Jan 8, 2006 | 05:17 AM
timb's Avatar
thank's Wanna, I'll crawl under her today and check on the lines. maybe that's why I only get 13 mpg with the old girl.
Old Jan 8, 2006 | 11:54 AM
Beamwalker's Avatar
inside fuel tank pickup tube develops a crack about size of fingernail. you may want to check that. happened on my 91. took me forever to locate and couple hours to fix. just stuck new piece of fuel line in i was back in business
Fallguy
Aug 1, 2010 09:37 AM
Red3quarter
Aug 14, 2008 08:13 PM
realsquash
38
Dec 19, 2006 09:14 AM
Dusty Ratcliff
May 20, 2006 08:53 PM
jd03ctd
19
Nov 14, 2003 09:00 PM
