truck not charging
Make sure the main body ground (goes from the negative battery terminal to the core support) is intact. Make sure the regulator case is a good ground. Make sure the blue wire at the reg has power with the key on. Check the wiring between the alt and the regulator for continuity.
The power is coming through the field. If you are using a decent test light it should be real dim on one wire if it lights at all, and the other one should look like you just hooked up to the battery. If you have one of those stupid LED test lights, get a test light with a real bulb.
Diesel-Dan
20
Sep 22, 2019 09:34 PM
GLHS
Feb 25, 2011 10:12 PM
Smokin96_12v
Jan 21, 2010 01:06 PM
bry@n
Nov 20, 2006 11:48 AM
