Truck Died
Old Dec 15, 2012 | 06:51 AM
bannerd's Avatar
Truck Died
Started to go up the road and the truck was chugging.. puff a blue smoke and she dies. Turns over but won't start, suggestions?
Old Dec 15, 2012 | 07:13 AM
bannerd's Avatar
Cracked all the lines and they look dead. I haven't changed me fuel filter in awhile would that cause it?
Old Dec 15, 2012 | 07:42 AM
BC847's Avatar
1st Generation Admin
Yes.
Old Dec 15, 2012 | 04:31 PM
bannerd's Avatar
Well changed the fuel filter and bled the lines. A bunch of brown stuff was coming out of the lines. I bled them till the diesel was coming out green. I suppose my fuel filter was messing up the entire injection system. Took the truck for a spin and runs way better than ever. Where would the brown come from?
Old Dec 15, 2012 | 05:22 PM
Rick 12v CTD's Avatar
the tank. And not trying to sound like a smart a**. stuff can actually grow in the tank.
Old Dec 15, 2012 | 05:27 PM
TheMrAMack's Avatar
You may have Algae in the tank. Run some Diesel 911 Bio Kleen Diesel fuel Biocide in the tank, and see if it will clear it out. http://www.powerservice.com/bk/
I've had good luck with their products, I run the normal stuff in my fuel fairly often. My Dad runs it in all of his Semi's also.
Old Dec 15, 2012 | 06:19 PM
bannerd's Avatar
Yeah, that's what my brother told me to put in there. Maybe that is what actually did it.
Runs fine now, I think a injector cleaned out.. I can cruise to 70mph like nothing now. I'll have to get more of their diesel stuff.
Thank!
Old Dec 15, 2012 | 08:07 PM
j_martin's Avatar
You don't have much in funky stuff on this engine (sensors, cat converters, etc.) If you pay attention to fuel quality and filters, it'll return good service.
Old Dec 15, 2012 | 08:36 PM
bannerd's Avatar
Question, where can I pick up the water in fuel sensor? Also, there is a steel line from the lift pump to the fuel filter, anyone have a part number for that?
Old Dec 16, 2012 | 01:19 AM
Bill Tomlinson's Avatar
When my truck has quit it has always been because of a poor electrical connection at the injection pump. Clean up the male connector and replace the female connector. Use a little grease on the terminal to prevent future problems.
The male connector should be cleaned with sand paper. It should really shine.
Old Dec 16, 2012 | 01:46 AM
I would suggest...as Bearkiller does...running a small clear replaceable in-line filter before your lift pump. I do and it amazes me the crud it picks up. This little filter will plug up first, but it's cheap and easy to replace if things start to go bad. Just keep a spare in the glove box.
Old Dec 16, 2012 | 01:38 PM
j_martin's Avatar
http://www.genosgarage.com/FLEETGUAR...1852-S-WIF-DG/
Old Dec 16, 2012 | 03:26 PM
bannerd's Avatar
Went to start the truck this am and it was shaking bad. I stepped on the gas and it level it out but a lot of blue smoke. Oil pressure was at 50 psi so that was good. Temperature is 0f here not sure what the heck is going on. I went to Napa and picked up a block heater. Its cold out and it did stall a few times. Once she warmed up all was well. Hopefully his block heater fixes this. Anything else I can do? I have the grill blocked off as Well.
Old Dec 16, 2012 | 03:38 PM
j_martin's Avatar
PS winter formula in the fuel.
Cold start at 0° will rattle and smoke till it warms up. Engine's cold, air's cold, fuel's cold, only about half of it will burn. If it wasn't a Cummins, it wouldn't even fire.
Plug in engine heater for an hour below freezing helps a lot.
Old Dec 16, 2012 | 04:51 PM
NE frmhnd's Avatar
Even better put it on a timer for 2 hours before you need it.
