transgo shift kit tranny problems
Old Nov 20, 2012 | 12:59 PM
speed75's Avatar
installed shift kit tfod-hd2 and know no overdrive what should i check
Old Nov 20, 2012 | 05:06 PM
BC847's Avatar
1st Generation Admin
Respectfully, everything you did.
Old Nov 20, 2012 | 07:41 PM
taterfarm's Avatar
any chance its a simple electrical connection problem?
is it correct that you should be able to hear the solenoid shift inside if you apply the ground to it?
Old Nov 20, 2012 | 07:52 PM
speed75's Avatar
is overdrive only controled by selenoid
Old Nov 20, 2012 | 08:28 PM
taterfarm's Avatar
everything on the top side of the separator plate is for overdrive isn't it? several valves and springs.
Old Nov 20, 2012 | 08:33 PM
taterfarm's Avatar
I sent you a PM
Old Nov 25, 2012 | 01:21 PM
speed75's Avatar
does anyone know if line pressure affects overdrive
Old Nov 26, 2012 | 09:00 PM
hdguage's Avatar
you have two springs reversed. I did the same thing and it drove me crazy. check them and make sure and follow the directions as to placement. good luck.
shrmpboatcptn
Nov 16, 2010 06:46 AM
USCGtraveler
19
Aug 10, 2004 08:22 AM
firepiper
Apr 16, 2004 11:02 PM
dansdodgediesel
Nov 28, 2003 09:17 AM
RickCJ
Jan 15, 2003 06:42 PM
