Trans temp switch question
Old May 15, 2011 | 08:15 PM
joeytechman's Avatar
Is this a NO , NC, or thermistor? Mine is open, cool truck. I'm trying to get my O.D. to work. TPS is good, adjusted, still no O.D. I looked in the 91.5 wiring diag. posted here, but couldn't find it
Thanks
Old May 15, 2011 | 08:23 PM
Onemoparnut's Avatar
I am pretty sure it is a nc switch. Unplug it and jump the two wires together and see if od works. Is there anything else that don't work like the charging system or the speed?
Old May 15, 2011 | 08:35 PM
charging system is ok, speedo is 10mph low, but works.
It makes sense it would be nc if its only purpose is to kick out od on a hot trans. Ill try a jumper.
Thanks for the quick response.
Old May 15, 2011 | 09:30 PM
Ok,tried a jumper, still no OD, where is the OD solenoid located on my trans./ transfer? Want to see if I have power.
Old May 15, 2011 | 11:55 PM
Lucas1's Avatar
its the vss on the transfer case most likely
broncobilly
Aug 27, 2009 11:19 PM
mar67655
Mar 21, 2009 05:35 AM
Richpwb
Aug 15, 2008 08:01 PM
djgaston
Oct 30, 2005 03:18 PM
live wire
Jul 21, 2003 07:26 AM
