trans to t-case coupler
Old Oct 23, 2009 | 04:50 AM
NO_SPRK's Avatar
Originally Posted by RonA
When i first installed it i was in the 700hp range.I checked it about 2 months ago and it was still fine. I turned the od of both sleeves concentric to the id and the same size. I cut them so that after cutting the teeth in them they would be the right length when mated together. I bored a set of jaws in the mill and cut 4, 45 degree slots 90 degrees apart( like slices of pie). This leaves 4 slots and 4 matching bosses that will mate together when placed end to end. I then took a piece of 3/8 wall tubing and bored a counter bore in in deep enough for the entire sleeve to slide into it and bottom out. I then made a cap for it and welded it in place. When done I slid it back on an arbor and re-cut the od and ends for balance.It only has about .001 clearance on the id and the ends. I used an end mill with .03 radius so there wasn't a sharp corner in the bottom of the slots. when mated together the two halves tend to not force each other apart and stay concentric. The outer tube just keeps them from seperating. Hope that makes sense.
that makes perfect sense. im very interested in this because i dont have an extra 600 to blow on a t-case when mine is perfectly fine. what i dont understand is how people say they cant hold up but no one talks about them breaking and its only a 6 spline difference. not like a old 10 spline to a 32 spline (chevy set up)
so did you have any issues on how each of the shafts are centered?
i think i sent you a PM, did you receive it?
Old Oct 23, 2009 | 06:52 AM
bgilbert's Avatar
It's not the difference in splines, it's the size of the transfer case input shaft that is the huge difference is size. When comparing the two (29 vs 23) the smaller 23 spline input looks half ton gasserous. But if it's still holding in Ron's high horse truck it may hold up to the power. Pretty sure he's even done boosted launches at the dragstrip with it.
Only thing is how much will he or a machine shop charge you for building a coupler?
Old Oct 23, 2009 | 07:14 AM
roxxx's Avatar
just finished a 5-speed swap on my friends truck made me think about converting myself but with the price of 29 spline NP205s it makes me think not!
so is there any reason why you couldnt get a custom 23 to 29 spline coupler to mate the two? there was lots of room around the trans and t-case output/input shafts.
did a search and didnt come up with anything
THANKS
It will cost you more to do a custom 205 than just getting a good one. I imagine were you are there is a lotta 4x4 shops and forums just start lurking on their forums heck if you were closer, I have a good one sitting here i would sell to you for what i paid for it
Old Oct 23, 2009 | 07:38 AM
NO_SPRK's Avatar
I found one in oregon I can get shipped for 500. If someone would buy my 47rh or my 727 and 205 I'd buy it right now. I got a wad of cash but I keep crunching numbers and coming up real close if I buy a t-case. I found the 29spline coupler online for about a hundred bucks. I was going to cut the 2 in half and have them welded and then put a sleave over it with swiss cheese holes and weld those all up.
How much do u want for your 205? How do you like your clutch? That's the con o right? I plan on buying that one
Old Oct 23, 2009 | 11:07 AM
kensmachine's Avatar
any one loooked at www nv4500.com
Old Oct 23, 2009 | 09:57 PM
NO_SPRK's Avatar
Yeah. Not as much info as quad 4x4
Old Oct 27, 2009 | 11:36 AM
RonA's Avatar
Just so there is no confusion. The coupler I made adapts the 23spline 47RH output to my existing 29 spline 205 transfer case input. Yes it has held up to boosted launches and a couple of years of use. There is no reason for it to fail really. The coupler can probably handle more than either of the shafts.
Old Oct 27, 2009 | 02:09 PM
Billut's Avatar
Man, a picture of that set-up would answer all the questions, you wouldn't happen to have one would you?
Old Oct 28, 2009 | 09:44 PM
RonA's Avatar
This is what the maching looks like for the ends. These 2 pieces are the left over short pieces that I used to set up the milling op. When done the 2 mated halves sit inside a piece of tubing with caps welded on the ends to allow for only a minimal amount of movement.
Old Oct 28, 2009 | 09:52 PM
NO_SPRK's Avatar
Sweet. Thanks for the pics that's what I expected to see
Old Dec 11, 2011 | 04:24 PM
done_my way's Avatar
Unhappy
The coupler in my gasser (23-spline) spit out the center internal snap-ring and has almost stripped the splines on one end. The shafts of the trans and t-case are fine. Soooooo, you guys whose coupler has held up, I applaud you, cuz they DO fail.
Old Dec 12, 2011 | 09:25 AM
texsasdiesel's Avatar
i dont' have the awesome skills that RonA does so i just ordered one of these for my crew cab build
http://shop.shsdiesel.com/23-spline-...329COUPLER.htm
James
mhuppertz
Jun 5, 2015 08:35 PM
winkdemon
Feb 20, 2013 12:02 PM
wyododge
Aug 18, 2011 07:48 AM
400Magnum
Feb 11, 2010 05:53 PM
J Cook
Dec 24, 2007 03:01 PM
