trans help
trans help
I'm planing to swap a cummins into my 85 W350 crew. The donor truck a 92 has a 5 speed but I want a automatic. This is my first diesel project. Can I use the auto in my truck???
Any suggestions greatly appriciated!
The Diesel trannys have a different bell housing. You'll need a donor from a diesel rig. If the 5-speed is good though you might have luck swaping an auto from someone who wants a Manual.
If the 518 your going to use is from a gasser it might have limited life behind the diesel. They were good transmission but tq of diesel isn't friendly. What gear ratio is in the truck now? Reason I ask is the non O/D trucks had 3.07 ratio, if your gasser is lower and I expect 4.11 , its going to be slow.
I'd go 5 speed...they're way more fun, put way more of the power to the ground and seem way more reliable to me...but i've heard that initially they had a lot of issues.
2000 rpm at 70 would be nice if you are setting a truck up. I get a little more rpm's with my 3.07 / 3spd set up. I would highly suggest an od definitely!
Where do you live? I have a 518 with OD/ Transfercase set up to trade for your 5speed/ transfercase set up
MoparTyson, the A518 that's in the diesels (actually, all of them) is a 727 with a OD housing bolted up. To get a A518 to run good, get a shift kit, adjust the bands (there is a link here to do it), and put in a good torque converter. That is all that's needed to make a good A518.
Maybe your Dakota had a A999? Did the Dakota have a lock-up converter?
I'm in arkansas. Sorry the 5speed is a 2 wheel. I was gonna use a divorced transfer out of a 72-74 truck.
