TRANS., FLUID?? SINY., or NOT???
I called qk. lube , for service on my trk., the guy said because the newer trks., require syn., fluid he flushes & refills w/ new syn., fluid . Do ido it, or stay w/ dextron???trk., 91 d350, auto.
From: Then, raised central PA; Now where ever Uncle Sam sends me.
I must agree on the dont flush. Just change the filter and refill with what ever fluid makes you happy. There is something about flushing that jut bugs me. I guess its cause I never really hear about people who just change oil and filter and go. But seems when people flush, then change and go leads to problems. I think that if it is not running free in regular use then why not it loose with a flush. But that is just my 2 cents......
I am a firm believer in you get what you pay for. With that said lets face it dollars and cents are what make things move. Go with what you can. Any new/clean oil is better then old burnt stuff. The biggest advantage to syn. is they hold up better to the regular and extreme abuse. I have seem 2stroke motocross bikes run almost a tank of UNMIXED fuel before the engine goes. It was being ran with amsoil prior. But if you go with DINO change often if you go with syn. you can go little longer but just watch it.
But thats my 2 cents all in all its your choice.
Plus, if your only dropping the pan and changing the filter you are only getting 1/2-3/4 of the fluid out anyway so whats the point of adding synthetic to what ever is still left in it.
